NVIDIA Quantun ESPRESSO hello world
Hi, yesterday I used NVIDIA Quantum ESPRESSO container:
https://catalog.ngc.nvidia.com/orgs/hpc/containers/quantum_espresso
, and tried to run the “hello world example”, the AU surface example suggested.
However, there were memory problems when running. I found a post:
https://lists.quantum-espresso.org/pipermail/users/2021-April/047396.html
and It seemed the minimum GPU memory should be > 32G ? cause it says:
“Ausurf is not that small of a system, you need at least 32 GB or 2x16 GB
to run it”, and I use two rtx2080ti gpu cards (2x 11G = 22G),
If this is why, can anyone kindly provides me a testing example (or links) before I
figure out how to write an input file for a system with less number of atoms?
I also attach the output log file.
qe_log.txt (14.4 KB)
Thank you!
You’re likely to find more people who are familiar with QE and with datasets for QE on the QE users forum.
