NVIDIA® Linux Graphics Debugger 2.0 is now available for download in the NVIDIA GameWorks Registered Developer Program. This release introduces the Range Profiler, extends OpenGL support, adds and improves graphics debugging tests and tools, and includes support for the Pascal GPU family. Enjoy!
The NVIDIA® Linux Graphics Debugger has been updated with these new v2.0 features:
• Frame debugging and profiling can be done on the latest Pascal family of GPUs (Requires a Linux driver version above 370.00)
• The Range Profiler is a powerful new view for determining how your application utilizes the GPU
○ All new performance library for improved GPU instrumentation as well as collection speed and accuracy
○ Improved data mining allowing the user to construct ranges from sections of the scene based on predefined or user-defined criteria
○ Elapsed GPU time is reported for each range, as well as hardware statistics detailing how efficiently the GPU was used
• Added new Disable Depth Test and Disable Cull Face performance tests
• Better support for GL_ARB_draw_indirect, GL_ARB_multi_draw_indirect, and other extensions
• Improved Resources View UI, including side by side selection and resource inspection
• Improved the Geometry View with powerful visualization capabilities and automated detection of vertex buffer data errors
• Added Issues column to the Events View to point out potential bugs and performance issues, correlated to the event stream
• Frame Debugger now has a Capture Next Frame feature to help track down intermittent issues
• Users can now retry capture if unsupported OpenGL operations are encountered
See all the features of the Linux Graphics Debugger and download it today!
https://developer.nvidia.com/linux-graphics-debugger
To download this version, you must be a member of the NVIDIA GameWorks Developer Program and signed into your account.
