Hardware:
CPU: Intel® Core™ i7-9800X CPU @ 3.80GHz
RAM: DDR4 4 x 16 GB
Motherboard: ASUSTeK COMPUTER INC. WS X299 SAGE (bios Version: 3203 06/10/2020)
+-[0000:64]-+-00.0-[65-68]----00.0-[66-68]--+-08.0-[67]--+-00.0 NVIDIA Corporation TU102 [GeForce RTX 2080 Ti]
| | | +-00.1 NVIDIA Corporation TU102 High Definition Audio Controller
| | | +-00.2 NVIDIA Corporation TU102 USB 3.1 Host Controller
| | | \-00.3 NVIDIA Corporation TU102 USB Type-C UCSI Controller
| | \-10.0-[68]--+-00.0 NVIDIA Corporation TU102 [GeForce RTX 2080 Ti]
+-[0000:16]-+-00.0-[17-1a]----00.0-[18-1a]--+-08.0-[19]----00.0 Intel Corporation 82599 10 Gigabit Network Connection
| | \-10.0-[1a]--+-00.0 NVIDIA Corporation TU102 [GeForce RTX 2080 Ti Rev. A]
cat /etc/redhat-release
CentOS Linux release 8.2.2004 (Core)
uname -r
4.18.0-193.19.1.el8_2.x86_64
Driver: NVIDIA-Linux-x86_64-455.23.04.run
All GPU work on this OS, but in journal Error, example:
Nov 25 12:26:21 nvtest.localdomain kernel: caller _nv000708rm+0x1af/0x200 [nvidia] mapping multiple BARs
Nov 25 12:26:24 nvtest.localdomain kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000c4000-0x000c7fff window]
cat /etc/os-release
Ubuntu 20.04.1 LTS
uname -r
5.4.0-53-generic
Driver: NVIDIA-Linux-x86_64-455.45.01.run
GPU 67, 68 work on this OS, 1a not working. In log Error (pci 19, 1a), example: BAR 1: failed to assign [mem size 0x10000000 64bit pref]
nvidia-smi
Wed Nov 25 16:12:11 2020
| NVIDIA-SMI 455.45.01 Driver Version: 455.45.01 CUDA Version: 11.1 |
| | | MIG M. |
| 0 GeForce RTX 208... Off | 00000000:67:00.0 Off | N/A |
| 29% 39C P8 20W / 250W | 5MiB / 11019MiB | 0% Default |
| | | N/A |
| 1 GeForce RTX 208... Off | 00000000:68:00.0 Off | N/A |
| 28% 37C P8 21W / 250W | 68MiB / 11016MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1038 G /usr/lib/xorg/Xorg 4MiB |
| 0 N/A N/A 1280 G /usr/bin/gnome-shell 0MiB |
| 1 N/A N/A 1038 G /usr/lib/xorg/Xorg 56MiB |
| 1 N/A N/A 1280 G /usr/bin/gnome-shell 10MiB |
cat /var/log/syslog | grep 1a:
Nov 25 16:02:57 arm1 kernel: [ 1.454939] pci 0000:1a:00.0: [10de:1e07] type 00 class 0x030000
Nov 25 16:02:57 arm1 kernel: [ 1.454962] pci 0000:1a:00.0: reg 0x10: [mem 0x95000000-0x95ffffff]
Nov 25 16:02:57 arm1 kernel: [ 1.454971] pci 0000:1a:00.0: reg 0x14: [mem 0xdfe0000000-0xdfefffffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.454980] pci 0000:1a:00.0: reg 0x1c: [mem 0xdff0000000-0xdff1ffffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.454986] pci 0000:1a:00.0: reg 0x24: [io 0x6000-0x607f]
Nov 25 16:02:57 arm1 kernel: [ 1.454991] pci 0000:1a:00.0: reg 0x30: [mem 0x96000000-0x9607ffff pref]
Nov 25 16:02:57 arm1 kernel: [ 1.454997] pci 0000:1a:00.0: enabling Extended Tags
Nov 25 16:02:57 arm1 kernel: [ 1.455061] pci 0000:1a:00.0: PME# supported from D0 D3hot
Nov 25 16:02:57 arm1 kernel: [ 1.455140] pci 0000:1a:00.1: [10de:10f7] type 00 class 0x040300
Nov 25 16:02:57 arm1 kernel: [ 1.455157] pci 0000:1a:00.1: reg 0x10: [mem 0x96080000-0x96083fff]
Nov 25 16:02:57 arm1 kernel: [ 1.455204] pci 0000:1a:00.1: enabling Extended Tags
Nov 25 16:02:57 arm1 kernel: [ 1.455289] pci 0000:1a:00.2: [10de:1ad6] type 00 class 0x0c0330
Nov 25 16:02:57 arm1 kernel: [ 1.455310] pci 0000:1a:00.2: reg 0x10: [mem 0xdff2000000-0xdff203ffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.455328] pci 0000:1a:00.2: reg 0x1c: [mem 0xdff2040000-0xdff204ffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.455348] pci 0000:1a:00.2: enabling Extended Tags
Nov 25 16:02:57 arm1 kernel: [ 1.455394] pci 0000:1a:00.2: PME# supported from D0 D3hot
Nov 25 16:02:57 arm1 kernel: [ 1.455438] pci 0000:1a:00.3: [10de:1ad7] type 00 class 0x0c8000
Nov 25 16:02:57 arm1 kernel: [ 1.455455] pci 0000:1a:00.3: reg 0x10: [mem 0x96084000-0x96084fff]
Nov 25 16:02:57 arm1 kernel: [ 1.455502] pci 0000:1a:00.3: enabling Extended Tags
Nov 25 16:02:57 arm1 kernel: [ 1.455548] pci 0000:1a:00.3: PME# supported from D0 D3hot
Nov 25 16:02:57 arm1 kernel: [ 2.476438] pci 0000:1a:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
Nov 25 16:02:57 arm1 kernel: [ 2.476438] pci 0000:1a:00.0: vgaarb: bridge control possible
Nov 25 16:02:57 arm1 kernel: [ 2.500848] pci 0000:1a:00.0: BAR 1: no space for [mem size 0x10000000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500849] pci 0000:1a:00.0: BAR 1: failed to assign [mem size 0x10000000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500850] pci 0000:1a:00.0: BAR 3: no space for [mem size 0x02000000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500850] pci 0000:1a:00.0: BAR 3: failed to assign [mem size 0x02000000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500851] pci 0000:1a:00.2: BAR 0: assigned [mem 0x960c0000-0x960fffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500859] pci 0000:1a:00.2: BAR 3: assigned [mem 0x96090000-0x9609ffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500952] pci 0000:1a:00.0: BAR 1: assigned [mem 0xd000000000-0xd00fffffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500959] pci 0000:1a:00.0: BAR 3: assigned [mem 0xd010000000-0xd011ffffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500966] pci 0000:1a:00.0: BAR 0: no space for [mem size 0x01000000]
Nov 25 16:02:57 arm1 kernel: [ 2.500967] pci 0000:1a:00.0: BAR 0: failed to assign [mem size 0x01000000]
Nov 25 16:02:57 arm1 kernel: [ 2.500968] pci 0000:1a:00.0: BAR 6: no space for [mem size 0x00080000 pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500968] pci 0000:1a:00.0: BAR 6: failed to assign [mem size 0x00080000 pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500969] pci 0000:1a:00.2: BAR 0: assigned [mem 0xd012000000-0xd01203ffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500976] pci 0000:1a:00.2: BAR 3: assigned [mem 0xd012040000-0xd01204ffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500983] pci 0000:1a:00.1: BAR 0: no space for [mem size 0x00004000]
Nov 25 16:02:57 arm1 kernel: [ 2.500984] pci 0000:1a:00.1: BAR 0: failed to assign [mem size 0x00004000]
Nov 25 16:02:57 arm1 kernel: [ 2.500985] pci 0000:1a:00.3: BAR 0: no space for [mem size 0x00001000]
Nov 25 16:02:57 arm1 kernel: [ 2.500985] pci 0000:1a:00.3: BAR 0: failed to assign [mem size 0x00001000]
Nov 25 16:02:57 arm1 kernel: [ 2.501016] pci_bus 0000:1a: resource 0 [io 0x6000-0x6fff]
Nov 25 16:02:57 arm1 kernel: [ 2.501016] pci_bus 0000:1a: resource 2 [mem 0xd000000000-0xd017ffffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.503521] pci 0000:1a:00.1: D0 power state depends on 0000:1a:00.0
Nov 25 16:02:57 arm1 kernel: [ 2.503570] pci 0000:1a:00.2: D0 power state depends on 0000:1a:00.0
Nov 25 16:02:57 arm1 kernel: [ 2.503812] pci 0000:1a:00.3: D0 power state depends on 0000:1a:00.0
Nov 25 16:02:57 arm1 kernel: [ 2.754493] xhci_hcd 0000:1a:00.2: xHCI Host Controller
Nov 25 16:02:57 arm1 kernel: [ 2.754495] xhci_hcd 0000:1a:00.2: new USB bus registered, assigned bus number 7
Nov 25 16:02:57 arm1 kernel: [ 2.755120] xhci_hcd 0000:1a:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
Nov 25 16:02:57 arm1 kernel: [ 2.755218] usb usb7: SerialNumber: 0000:1a:00.2
Nov 25 16:02:57 arm1 kernel: [ 2.755432] xhci_hcd 0000:1a:00.2: xHCI Host Controller
Nov 25 16:02:57 arm1 kernel: [ 2.755434] xhci_hcd 0000:1a:00.2: new USB bus registered, assigned bus number 8
Nov 25 16:02:57 arm1 kernel: [ 2.755435] xhci_hcd 0000:1a:00.2: Host supports USB 3.1 Enhanced SuperSpeed
Nov 25 16:02:57 arm1 kernel: [ 2.755461] usb usb8: SerialNumber: 0000:1a:00.2
Nov 25 16:02:57 arm1 kernel: [ 2.964130] nvidia-gpu 0000:1a:00.3: pcim_iomap failed
Nov 25 16:02:57 arm1 kernel: [ 2.964201] nvidia-gpu: probe of 0000:1a:00.3 failed with error -12
Nov 25 16:02:57 arm1 kernel: [ 11.639229] snd_hda_intel 0000:1a:00.1: Disabling MSI
Nov 25 16:02:57 arm1 kernel: [ 11.639251] snd_hda_intel 0000:1a:00.1: Handle vga_switcheroo audio client
Nov 25 16:02:57 arm1 kernel: [ 11.639268] snd_hda_intel 0000:1a:00.1: can't ioremap BAR 0: [??? 0x00000000 flags 0x0]
Nov 25 16:02:57 arm1 kernel: [ 11.639269] snd_hda_intel 0000:1a:00.1: ioremap error
Nov 25 16:02:57 arm1 kernel: [ 11.987947] nvidia 0000:1a:00.0: enabling device (0100 -> 0103)
Nov 25 16:02:57 arm1 kernel: [ 11.988020] NVRM: BAR0 is 0M @ 0x0 (PCI:0000:1a:00.0)
Nov 25 16:02:57 arm1 kernel: [ 11.988027] nvidia: probe of 0000:1a:00.0 failed with error -1
cat /var/log/syslog | grep 19:
Nov 25 16:02:57 arm1 kernel: [ 1.454558] pci 0000:19:00.0: [8086:1557] type 00 class 0x020000
Nov 25 16:02:57 arm1 kernel: [ 1.454579] pci 0000:19:00.0: reg 0x10: [mem 0xdff2200000-0xdff227ffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.454586] pci 0000:19:00.0: reg 0x18: [io 0x7000-0x701f]
Nov 25 16:02:57 arm1 kernel: [ 1.454602] pci 0000:19:00.0: reg 0x20: [mem 0xdff2280000-0xdff2283fff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.454609] pci 0000:19:00.0: reg 0x30: [mem 0x96200000-0x9627ffff pref]
Nov 25 16:02:57 arm1 kernel: [ 1.454667] pci 0000:19:00.0: PME# supported from D0 D3hot D3cold
Nov 25 16:02:57 arm1 kernel: [ 1.454696] pci 0000:19:00.0: reg 0x184: [mem 0x00000000-0x00003fff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.454697] pci 0000:19:00.0: VF(n) BAR0 space: [mem 0x00000000-0x000fffff 64bit pref] (contains BAR0 for 64 VFs)
Nov 25 16:02:57 arm1 kernel: [ 1.454712] pci 0000:19:00.0: reg 0x190: [mem 0x00000000-0x00003fff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.454713] pci 0000:19:00.0: VF(n) BAR3 space: [mem 0x00000000-0x000fffff 64bit pref] (contains BAR3 for 64 VFs)
Nov 25 16:02:57 arm1 kernel: [ 2.500711] pci 0000:19:00.0: BAR 7: no space for [mem size 0x00100000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500712] pci 0000:19:00.0: BAR 7: failed to assign [mem size 0x00100000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500715] pci 0000:19:00.0: BAR 10: no space for [mem size 0x00100000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500715] pci 0000:19:00.0: BAR 10: failed to assign [mem size 0x00100000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500762] pci 0000:19:00.0: BAR 0: assigned [mem 0x96280000-0x962fffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500769] pci 0000:19:00.0: BAR 4: no space for [mem size 0x00004000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500770] pci 0000:19:00.0: BAR 4: failed to assign [mem size 0x00004000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500771] pci 0000:19:00.0: BAR 7: no space for [mem size 0x00100000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500771] pci 0000:19:00.0: BAR 7: failed to assign [mem size 0x00100000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500772] pci 0000:19:00.0: BAR 10: no space for [mem size 0x00100000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500772] pci 0000:19:00.0: BAR 10: failed to assign [mem size 0x00100000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500829] pci 0000:19:00.0: BAR 0: assigned [mem 0x96100000-0x9617ffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500835] pci 0000:19:00.0: BAR 6: assigned [mem 0x96180000-0x961fffff pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500836] pci 0000:19:00.0: BAR 4: no space for [mem size 0x00004000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500837] pci 0000:19:00.0: BAR 4: failed to assign [mem size 0x00004000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500837] pci 0000:19:00.0: BAR 7: no space for [mem size 0x00100000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500838] pci 0000:19:00.0: BAR 7: failed to assign [mem size 0x00100000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500839] pci 0000:19:00.0: BAR 10: no space for [mem size 0x00100000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500839] pci 0000:19:00.0: BAR 10: failed to assign [mem size 0x00100000 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500922] pci 0000:19:00.0: BAR 0: assigned [mem 0xd018000000-0xd01807ffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500929] pci 0000:19:00.0: BAR 6: no space for [mem size 0x00080000 pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500930] pci 0000:19:00.0: BAR 6: failed to assign [mem size 0x00080000 pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500930] pci 0000:19:00.0: BAR 4: assigned [mem 0xd018080000-0xd018083fff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500937] pci 0000:19:00.0: BAR 7: assigned [mem 0xd018084000-0xd018183fff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.500940] pci 0000:19:00.0: BAR 10: assigned [mem 0xd018184000-0xd018283fff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.501015] pci_bus 0000:19: resource 0 [io 0x7000-0x7fff]
Nov 25 16:02:57 arm1 kernel: [ 2.501015] pci_bus 0000:19: resource 2 [mem 0xd018000000-0xd0184fffff 64bit pref]
cat /var/log/syslog | grep 67:
Nov 25 16:02:57 arm1 nvidia-persistenced: device 0000:67:00.0 - registered
Nov 25 16:02:57 arm1 kernel: [ 1.965918] pci 0000:67:00.0: [10de:1e04] type 00 class 0x030000
Nov 25 16:02:57 arm1 kernel: [ 1.965941] pci 0000:67:00.0: reg 0x10: [mem 0xd7000000-0xd7ffffff]
Nov 25 16:02:57 arm1 kernel: [ 1.965950] pci 0000:67:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.965960] pci 0000:67:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.965965] pci 0000:67:00.0: reg 0x24: [io 0xb000-0xb07f]
Nov 25 16:02:57 arm1 kernel: [ 1.965971] pci 0000:67:00.0: reg 0x30: [mem 0xd8000000-0xd807ffff pref]
Nov 25 16:02:57 arm1 kernel: [ 1.965977] pci 0000:67:00.0: enabling Extended Tags
Nov 25 16:02:57 arm1 kernel: [ 1.966040] pci 0000:67:00.0: PME# supported from D0 D3hot
Nov 25 16:02:57 arm1 kernel: [ 1.966115] pci 0000:67:00.1: [10de:10f7] type 00 class 0x040300
Nov 25 16:02:57 arm1 kernel: [ 1.966132] pci 0000:67:00.1: reg 0x10: [mem 0xd8080000-0xd8083fff]
Nov 25 16:02:57 arm1 kernel: [ 1.966178] pci 0000:67:00.1: enabling Extended Tags
Nov 25 16:02:57 arm1 kernel: [ 1.966270] pci 0000:67:00.2: [10de:1ad6] type 00 class 0x0c0330
Nov 25 16:02:57 arm1 kernel: [ 1.966290] pci 0000:67:00.2: reg 0x10: [mem 0xd2000000-0xd203ffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.966308] pci 0000:67:00.2: reg 0x1c: [mem 0xd2040000-0xd204ffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.966327] pci 0000:67:00.2: enabling Extended Tags
Nov 25 16:02:57 arm1 kernel: [ 1.966373] pci 0000:67:00.2: PME# supported from D0 D3hot
Nov 25 16:02:57 arm1 kernel: [ 1.966417] pci 0000:67:00.3: [10de:1ad7] type 00 class 0x0c8000
Nov 25 16:02:57 arm1 kernel: [ 1.966434] pci 0000:67:00.3: reg 0x10: [mem 0xd8084000-0xd8084fff]
Nov 25 16:02:57 arm1 kernel: [ 1.966480] pci 0000:67:00.3: enabling Extended Tags
Nov 25 16:02:57 arm1 kernel: [ 1.966526] pci 0000:67:00.3: PME# supported from D0 D3hot
Nov 25 16:02:57 arm1 kernel: [ 2.476438] pci 0000:67:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
Nov 25 16:02:57 arm1 kernel: [ 2.476438] pci 0000:67:00.0: vgaarb: bridge control possible
Nov 25 16:02:57 arm1 kernel: [ 2.501078] pci_bus 0000:67: resource 0 [io 0xb000-0xbfff]
Nov 25 16:02:57 arm1 kernel: [ 2.501078] pci_bus 0000:67: resource 1 [mem 0xd7000000-0xd80fffff]
Nov 25 16:02:57 arm1 kernel: [ 2.501079] pci_bus 0000:67: resource 2 [mem 0xc0000000-0xd20fffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.503885] pci 0000:67:00.1: D0 power state depends on 0000:67:00.0
Nov 25 16:02:57 arm1 kernel: [ 2.503929] pci 0000:67:00.2: D0 power state depends on 0000:67:00.0
Nov 25 16:02:57 arm1 kernel: [ 2.504135] pci 0000:67:00.3: D0 power state depends on 0000:67:00.0
Nov 25 16:02:57 arm1 kernel: [ 2.755667] xhci_hcd 0000:67:00.2: xHCI Host Controller
Nov 25 16:02:57 arm1 kernel: [ 2.755669] xhci_hcd 0000:67:00.2: new USB bus registered, assigned bus number 9
Nov 25 16:02:57 arm1 kernel: [ 2.756280] xhci_hcd 0000:67:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
Nov 25 16:02:57 arm1 kernel: [ 2.756376] usb usb9: SerialNumber: 0000:67:00.2
Nov 25 16:02:57 arm1 kernel: [ 2.756497] xhci_hcd 0000:67:00.2: xHCI Host Controller
Nov 25 16:02:57 arm1 kernel: [ 2.756498] xhci_hcd 0000:67:00.2: new USB bus registered, assigned bus number 10
Nov 25 16:02:57 arm1 kernel: [ 2.756500] xhci_hcd 0000:67:00.2: Host supports USB 3.1 Enhanced SuperSpeed
Nov 25 16:02:57 arm1 kernel: [ 2.756525] usb usb10: SerialNumber: 0000:67:00.2
Nov 25 16:02:57 arm1 kernel: [ 11.639400] snd_hda_intel 0000:67:00.1: Disabling MSI
Nov 25 16:02:57 arm1 kernel: [ 11.639417] snd_hda_intel 0000:67:00.1: Handle vga_switcheroo audio client
Nov 25 16:02:57 arm1 kernel: [ 11.988042] nvidia 0000:67:00.0: enabling device (0100 -> 0103)
Nov 25 16:02:57 arm1 kernel: [ 11.988086] nvidia 0000:67:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
Nov 25 16:02:57 arm1 kernel: [ 12.423398] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:67:00.0 on minor 0
Nov 25 16:02:57 arm1 kernel: [ 13.555268] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:08.0/0000:67:00.1/sound/card2/input15
Nov 25 16:02:57 arm1 kernel: [ 13.555302] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:08.0/0000:67:00.1/sound/card2/input16
Nov 25 16:02:57 arm1 kernel: [ 13.555383] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:08.0/0000:67:00.1/sound/card2/input17
Nov 25 16:02:57 arm1 kernel: [ 13.555430] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:08.0/0000:67:00.1/sound/card2/input18
Nov 25 16:02:57 arm1 kernel: [ 13.555491] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:08.0/0000:67:00.1/sound/card2/input19
Nov 25 16:02:57 arm1 kernel: [ 13.555538] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:08.0/0000:67:00.1/sound/card2/input20
Nov 25 16:02:57 arm1 kernel: [ 13.555570] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:08.0/0000:67:00.1/sound/card2/input21
cat /var/log/syslog | grep 68:
Nov 25 16:02:57 arm1 nvidia-persistenced: device 0000:68:00.0 - registered
Nov 25 16:02:57 arm1 kernel: [ 1.966604] pci 0000:68:00.0: [10de:1e04] type 00 class 0x030000
Nov 25 16:02:57 arm1 kernel: [ 1.966628] pci 0000:68:00.0: reg 0x10: [mem 0xd5000000-0xd5ffffff]
Nov 25 16:02:57 arm1 kernel: [ 1.966639] pci 0000:68:00.0: reg 0x14: [mem 0xa0000000-0xafffffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.966651] pci 0000:68:00.0: reg 0x1c: [mem 0xb0000000-0xb1ffffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.966658] pci 0000:68:00.0: reg 0x24: [io 0xa000-0xa07f]
Nov 25 16:02:57 arm1 kernel: [ 1.966665] pci 0000:68:00.0: reg 0x30: [mem 0xd6000000-0xd607ffff pref]
Nov 25 16:02:57 arm1 kernel: [ 1.966671] pci 0000:68:00.0: enabling Extended Tags
Nov 25 16:02:57 arm1 kernel: [ 1.966687] pci 0000:68:00.0: BAR 3: assigned to efifb
Nov 25 16:02:57 arm1 kernel: [ 1.966735] pci 0000:68:00.0: PME# supported from D0 D3hot
Nov 25 16:02:57 arm1 kernel: [ 1.966785] pci 0000:68:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x16 link at 0000:66:10.0 (capable of 126.016 Gb/s with 8 GT/s x16 link)
Nov 25 16:02:57 arm1 kernel: [ 1.966812] pci 0000:68:00.1: [10de:10f7] type 00 class 0x040300
Nov 25 16:02:57 arm1 kernel: [ 1.966829] pci 0000:68:00.1: reg 0x10: [mem 0xd6080000-0xd6083fff]
Nov 25 16:02:57 arm1 kernel: [ 1.966875] pci 0000:68:00.1: enabling Extended Tags
Nov 25 16:02:57 arm1 kernel: [ 1.966960] pci 0000:68:00.2: [10de:1ad6] type 00 class 0x0c0330
Nov 25 16:02:57 arm1 kernel: [ 1.966981] pci 0000:68:00.2: reg 0x10: [mem 0xb2000000-0xb203ffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.966999] pci 0000:68:00.2: reg 0x1c: [mem 0xb2040000-0xb204ffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 1.967018] pci 0000:68:00.2: enabling Extended Tags
Nov 25 16:02:57 arm1 kernel: [ 1.967064] pci 0000:68:00.2: PME# supported from D0 D3hot
Nov 25 16:02:57 arm1 kernel: [ 1.967113] pci 0000:68:00.3: [10de:1ad7] type 00 class 0x0c8000
Nov 25 16:02:57 arm1 kernel: [ 1.967130] pci 0000:68:00.3: reg 0x10: [mem 0xd6084000-0xd6084fff]
Nov 25 16:02:57 arm1 kernel: [ 1.967176] pci 0000:68:00.3: enabling Extended Tags
Nov 25 16:02:57 arm1 kernel: [ 1.967221] pci 0000:68:00.3: PME# supported from D0 D3hot
Nov 25 16:02:57 arm1 kernel: [ 2.476438] pci 0000:68:00.0: vgaarb: setting as boot VGA device
Nov 25 16:02:57 arm1 kernel: [ 2.476438] pci 0000:68:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Nov 25 16:02:57 arm1 kernel: [ 2.476438] pci 0000:68:00.0: vgaarb: bridge control possible
Nov 25 16:02:57 arm1 kernel: [ 2.501079] pci_bus 0000:68: resource 0 [io 0xa000-0xafff]
Nov 25 16:02:57 arm1 kernel: [ 2.501080] pci_bus 0000:68: resource 1 [mem 0xd5000000-0xd60fffff]
Nov 25 16:02:57 arm1 kernel: [ 2.501081] pci_bus 0000:68: resource 2 [mem 0xa0000000-0xb20fffff 64bit pref]
Nov 25 16:02:57 arm1 kernel: [ 2.504147] pci 0000:68:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Nov 25 16:02:57 arm1 kernel: [ 2.504192] pci 0000:68:00.1: D0 power state depends on 0000:68:00.0
Nov 25 16:02:57 arm1 kernel: [ 2.504237] pci 0000:68:00.2: D0 power state depends on 0000:68:00.0
Nov 25 16:02:57 arm1 kernel: [ 2.504361] pci 0000:68:00.3: D0 power state depends on 0000:68:00.0
Nov 25 16:02:57 arm1 kernel: [ 2.756714] xhci_hcd 0000:68:00.2: xHCI Host Controller
Nov 25 16:02:57 arm1 kernel: [ 2.756716] xhci_hcd 0000:68:00.2: new USB bus registered, assigned bus number 11
Nov 25 16:02:57 arm1 kernel: [ 2.757305] xhci_hcd 0000:68:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
Nov 25 16:02:57 arm1 kernel: [ 2.757390] usb usb11: SerialNumber: 0000:68:00.2
Nov 25 16:02:57 arm1 kernel: [ 2.757499] xhci_hcd 0000:68:00.2: xHCI Host Controller
Nov 25 16:02:57 arm1 kernel: [ 2.757500] xhci_hcd 0000:68:00.2: new USB bus registered, assigned bus number 12
Nov 25 16:02:57 arm1 kernel: [ 2.757501] xhci_hcd 0000:68:00.2: Host supports USB 3.1 Enhanced SuperSpeed
Nov 25 16:02:57 arm1 kernel: [ 2.757526] usb usb12: SerialNumber: 0000:68:00.2
Nov 25 16:02:57 arm1 kernel: [ 11.639545] snd_hda_intel 0000:68:00.1: Disabling MSI
Nov 25 16:02:57 arm1 kernel: [ 11.639559] snd_hda_intel 0000:68:00.1: Handle vga_switcheroo audio client
Nov 25 16:02:57 arm1 kernel: [ 12.104147] nvidia 0000:68:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
Nov 25 16:02:57 arm1 kernel: [ 12.423453] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:68:00.0 on minor 1
Nov 25 16:02:57 arm1 kernel: [ 13.554660] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:10.0/0000:68:00.1/sound/card3/input22
Nov 25 16:02:57 arm1 kernel: [ 13.554781] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:10.0/0000:68:00.1/sound/card3/input23
Nov 25 16:02:57 arm1 kernel: [ 13.554865] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:10.0/0000:68:00.1/sound/card3/input24
Nov 25 16:02:57 arm1 kernel: [ 13.554921] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:10.0/0000:68:00.1/sound/card3/input25
Nov 25 16:02:57 arm1 kernel: [ 13.554996] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:10.0/0000:68:00.1/sound/card3/input26
Nov 25 16:02:57 arm1 kernel: [ 13.555088] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:10.0/0000:68:00.1/sound/card3/input27
Nov 25 16:02:57 arm1 kernel: [ 13.555192] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:64/0000:64:00.0/0000:65:00.0/0000:66:10.0/0000:68:00.1/sound/card3/input28
root@arm1:~# lspci -s 1a:00.0 -vv
1a:00.0 VGA compatible controller: NVIDIA Corporation TU102 [GeForce RTX 2080 Ti Rev. A] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. TU102 [GeForce RTX 2080 Ti Rev. A]
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 25
NUMA node: 0
Region 0: Memory at <ignored> (32-bit, non-prefetchable)
Region 1: Memory at d000000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at d010000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at 6000 [size=128]
Expansion ROM at <ignored> [disabled]
Capabilities: [60] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [78] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
LnkCap: Port #16, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <1us, L1 <4us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s (ok), Width x16 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, NROPrPrP-, LTR+
10BitTagComp-, 10BitTagReq-, OBFF Via message, ExtFmt-, EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
AtomicOpsCtl: ReqEn-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [250 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [258 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=255us PortTPowerOnTime=10us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=10us
Capabilities: [128 v1] Power Budgeting <?>
Capabilities: [420 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn-, PerformEqu-
LaneErrStat: 0
Capabilities: [bb0 v1] Resizable BAR <?>
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
root@arm1:~# lspci -s 67:00.0 -vv
67:00.0 VGA compatible controller: NVIDIA Corporation TU102 [GeForce RTX 2080 Ti] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. TU102 [GeForce RTX 2080 Ti]
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 105
NUMA node: 0
Region 0: Memory at d7000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at c0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at d0000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at b000 [size=128]
Expansion ROM at d8000000 [virtual] [disabled] [size=512K]
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee001b8 Data: 0000
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #8, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <512ns, L1 <16us
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s (downgraded), Width x16 (ok)
DevCap2: Completion Timeout: Range AB, TimeoutDis+, NROPrPrP-, LTR-
FRS-
Status: InProgress-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
LaneErrStat: 0
Kernel driver in use: nvidia
root@arm1:~# lspci -s 68:00.0 -vv
68:00.0 VGA compatible controller: NVIDIA Corporation TU102 [GeForce RTX 2080 Ti] (rev a1) (prog-if 00 [VGA controller])
Latency: 0
Interrupt: pin A routed to IRQ 104
NUMA node: 0
Region 0: Memory at d5000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at a0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at b0000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at a000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Address: 00000000fee00198 Data: 0000
LnkCap: Port #16, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <512ns, L1 <16us
FRS-
Status: InProgress-
LaneErrStat: 0
root@arm1:~# lspci -s 19:00.0 -vv
19:00.0 Ethernet controller: Intel Corporation 82599 10 Gigabit Network Connection (rev 01)
Subsystem: Intel Corporation 82599 10 Gigabit Network Connection
Latency: 0, Cache Line Size: 32 bytes
NUMA node: 0
Region 0: Memory at d018000000 (64-bit, prefetchable) [size=512K]
Region 2: I/O ports at 7000 [size=32]
Region 4: Memory at d018080000 (64-bit, prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable+ Count=64 Masked-
Vector table: BAR=4 offset=00000000
PBA: BAR=4 offset=00002000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #8, Speed 5GT/s, Width x8, ASPM L0s, Exit Latency L0s <2us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkSta: Speed 5GT/s (ok), Width x8 (ok)
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, NROPrPrP-, LTR-
10BitTagComp-, 10BitTagReq-, OBFF Not Supported, ExtFmt-, EETLPPrefix-
FRS-, TPHComp-, ExtTPHComp-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [e0] Vital Product Data
pcilib: sysfs_read_vpd: read failed: Input/output error
Not readable
Capabilities: [100 v1] Advanced Error Reporting
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
Capabilities: [140 v1] Device Serial Number f0-b4-d2-ff-ff-4b-90-a0
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 0
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
IOVCap: Migration-, Interrupt Message Number: 000
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy+
IOVSta: Migration-
Initial VFs: 64, Total VFs: 64, Number of VFs: 0, Function Dependency Link: 00
VF offset: 128, stride: 2, Device ID: 10ed
Supported Page Size: 00000553, System Page Size: 00000001
Region 0: Memory at 000000d018084000 (64-bit, prefetchable)
Region 3: Memory at 000000d018184000 (64-bit, prefetchable)
VF Migration: offset: 00000000, BIR: 0
Kernel driver in use: ixgbe
Kernel modules: ixgbe
