nVidia Research Paper on SpMV (code doesn't compile)
For my own learning, I’m trying to implement an optimized algorithm for sparse matrix-vector multiplication on a GPU with the sparse matrix stored in CSR format. I’m learning from the nVidia research paper here: http://www.nvidia.com/docs/IO/66889/nvr-2008-004.pdf
The issue that I’m having (and I’m sure it’s simple) is that the compiler is raising an “error: incomplete type is not allowed” message for the “shared float vals;” line when I try to compile the following kernel:
__global__ void spmv_csr_vector_kernel (const int num_rows, const int *ptr, const int *indices, const float *data, const float *x , float *y) {
	__shared__ float vals[];
	int thread_id = blockDim.x * blockIdx.x + threadIdx.x;	// global thread index
	int warp_id = thread_id / 32;							// global warp index
	int lane = thread_id & (32 - 1);						// thread index within the warp
	// one warp per row
	int row = warp_id;
	if (row < num_rows) {
		int row_start = ptr[row];
		int row_end = ptr[row+1];
		// compute running sum per thread
		vals [threadIdx.x] = 0;
		for (int jj = row_start + lane; jj < row_end; jj += 32)
			vals [ threadIdx.x ] += data [ jj ] * x [ indices [ jj ]];
		// parallel reduction in shared memory
		if ( lane < 16) vals[threadIdx.x] += vals[threadIdx.x + 16];
		if ( lane < 8) vals[threadIdx.x] += vals[threadIdx.x + 8];
		if ( lane < 4) vals[threadIdx.x] += vals[threadIdx.x + 4];
		if ( lane < 2) vals[threadIdx.x] += vals[threadIdx.x + 2];
		if ( lane < 1) vals[threadIdx.x] += vals[threadIdx.x + 1];
		// first thread writes the result
		if (lane == 0)
			y[row] += vals[threadIdx.x];
Note: this is the code from page 17 of the report.
Any idea how to fix this simple error?
You need to either use a fixed array size, or declare the array as extern [font=“Courier New”]shared[/font] and provide the size (in bytes) at runtime as the third launch configuration parameter.
