Nvidia Riva "sudo bash riva_init.sh" error
Hello, I’m having a problem with initializing Nvidia Riva (The server side)
My operating system for the server is Ubuntu Server
Here’s the log:
ai@ai:~/riva/riva_quickstart_v2.14.0$ sudo bash riva_init.sh
Please enter API key for ngc.nvidia.com:
Logging into NGC docker registry if necessary…
Pulling required docker images if necessary…
Note: This may take some time, depending on the speed of your Internet connection.
Pulling Riva Speech Server images.
Image nvcr.io/nvidia/riva/riva-speech:2.14.0 exists. Skipping.
Image nvcr.io/nvidia/riva/riva-speech:2.14.0-servicemaker exists. Skipping.
Downloading models (RMIRs) from NGC…
Note: this may take some time, depending on the speed of your Internet connection.
To skip this process and use existing RMIRs set the location and corresponding flag in config.sh.
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as ‘legacy’
nvidia-container-cli: initialization error: load library failed: libnvidia-ml.so.1: cannot open shared object file: no such file or directory: unknown.
Error in downloading models.
Fixed! I just had to run the
nvidia-smi
command and if there was an error, then it would give you this.
