My laptop is DELL G15 5511. It works right on windows, with 2K @75hz full rgb output hdmi. But it not work on linux. When I force set (xrandr --output HDMI-0 --mode 2560x1440 --rate 75.00 --output DP-4 --off) . then the screen become black and no more image output, what I can do is change to tty F1, then restart lightdm. The output hightest set is 2K @60hz with full rgb, it can not set to 2K @75hz with full rgb or limit rgb on nvidia-settings . Finally I found it can be set 2K @75hz on YCbCr422 limit or YCbCr444 color mode on nvidia-settings. I really not know how to fix it, I found some solution was add xrandr opintion with -set "Broadcast RGB " "Full ", but it is only to be useful on intel and amd graphical card, not working on nvidia. BTW, it is all right on inside screen, it can be output on 1080P @ 165 hz full rgb mode, bath on windows and linux. The linux driver version is 560.35.03.
Related topics
Topic | Replies | Views | Activity | |
Can't use 2560x1440@55Hz over HDMI under linux (win7 works) | 0 | 2029 | January 25, 2013 | |
NVIDIA 450.57 - No 4k output @ 60HZ | 0 | 347 | August 21, 2020 | |
4k Monitor cannot get maximum resolution and refresh rate in ubuntu | 1 | 886 | May 1, 2022 | |
[525.x] Cannot set third monitor to maximum Hz and one of the monitors does not start after suspend. RTX3060 Mobile | 2 | 440 | January 13, 2023 | |
Cannot set 2560x1440 (maximum is 2048x1080) on Geforce GT525M | 0 | 4111 | September 8, 2016 | |
How to enable a resolution of 2560x1080 via HDMI 1.3 (GeForce 9600M GT)? | 3 | 10471 | April 22, 2014 | |
525.53 RTX 3060 HDMI 4k 144Hz black screen | 0 | 563 | November 11, 2022 | |
2560x1440@60 Hz mode stopped working over HDMI | 9 | 11549 | August 11, 2015 | |
Rtx 3090 linux samsung g9 no 240Hz support | 5 | 1830 | December 12, 2021 | |
RTX 2080 Ti. Unable to achieve HDMI 4k60 with 444 Chroma subsampling under CentOS. | 2 | 2183 | October 12, 2021 |
