I fresh install Manjaro xcfe with non-free driver after install when I boot my laptop I got black screen but I can use tty2 terminal lightdm fail start now my laptop use nvidia-418xx I think I have to config about hybrid GPU but I don’t know how to do it please help me thank you
nvidia-bug-report.log.gz (1.1 MB)
Please run nvidia-bug-report.sh as root and attach the resulting .gz file to your post. Hovering the mouse over an existing post of yours will reveal a paperclip icon.
https://devtalk.nvidia.com/default/topic/1043347/announcements/attaching-files-to-forum-topics-posts/
Please delete /etc/X11/xorg.conf.d/90-mhwd.conf
and create /etc/X11/xorg.conf with contents
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia" 0 0
Inactive "amd"
EndSection
Section "Monitor"
Identifier "Monitor0"
Modeline "1280x720_60.00" 74.48 1280 1336 1472 1664 720 721 724 746 -HSync +Vsync
EndSection
Section "Device"
Identifier "amd"
Driver "modesetting"
Option "AccelMethod" "none"
BusID "PCI:4:0:0"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BusID "PCI:1:0:0"
Option "AllowEmptyInitialConfiguration"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
Monitor "Monitor0"
SubSection "Display"
Virtual 1920 1080
EndSubSection
EndSection
and configure lightdm like this:
https://wiki.archlinux.org/index.php/NVIDIA_Optimus#LightDM
it still not working
/etc/lightdm/lightdm.conf
[Seat:*]
display-setup-script=/etc/lightdm/display_setup.sh
in this config I just add in the bottom of file don’t delete all file
No idea what you’ve done now. Please create the xorg.conf. Also lightdm doesn’t seem to start up at all, there seems to be an error in the lightdm config.
I created the file but it not work
I don’t see any /etc/X11/xorg.conf in the logs.
sorry that my flaw
now I edit this config
[Seat:*]
and when I reboot it make my laptop blink screen and now i can’t access to tty
when i edit this file laptop being blink screen (now I can access file by dual boot)
[Seat:*]
# General configuration
# start-default-seat = True to always start one seat if none are defined in the configuration
# greeter-user = User to run greeter as
# minimum-display-number = Minimum display number to use for X servers
# minimum-vt = First VT to run displays on
# lock-memory = True to prevent memory from being paged to disk
# user-authority-in-system-dir = True if session authority should be in the system location
# guest-account-script = Script to be run to setup guest account
# logind-check-graphical = True to on start seats that are marked as graphical by logind
# log-directory = Directory to log information to
# run-directory = Directory to put running state in
# cache-directory = Directory to cache to
# sessions-directory = Directory to find sessions
# remote-sessions-directory = Directory to find remote sessions
# greeters-directory = Directory to find greeters
# backup-logs = True to move add a .old suffix to old log files when opening new ones
# dbus-service = True if LightDM provides a D-Bus service to control it
[LightDM]
#start-default-seat=true
#greeter-user=lightdm
#minimum-display-number=0
#minimum-vt=7 # Setting this to a value < 7 implies security issues, see FS#46799
#lock-memory=true
#user-authority-in-system-dir=false
#guest-account-script=guest-account
#logind-check-graphical=false
#log-directory=/var/log/lightdm
run-directory=/run/lightdm
#cache-directory=/var/cache/lightdm
#sessions-directory=/usr/share/lightdm/sessions:/usr/share/xsessions:/usr/share/wayland-sessions
#remote-sessions-directory=/usr/share/lightdm/remote-sessions
#greeters-directory=$XDG_DATA_DIRS/lightdm/greeters:$XDG_DATA_DIRS/xgreeters
#backup-logs=true
#dbus-service=true
# Seat configuration
# Seat configuration is matched against the seat name glob in the section, for example:
# [Seat:*] matches all seats and is applied first.
# [Seat:seat0] matches the seat named "seat0".
# [Seat:seat-thin-client*] matches all seats that have names that start with "seat-thin-client".
# type = Seat type (local, xremote)
# pam-service = PAM service to use for login
# pam-autologin-service = PAM service to use for autologin
# pam-greeter-service = PAM service to use for greeters
# xserver-command = X server command to run (can also contain arguments e.g. X -special-option)
# xmir-command = Xmir server command to run (can also contain arguments e.g. Xmir -special-option)
# xserver-config = Config file to pass to X server
# xserver-layout = Layout to pass to X server
# xserver-allow-tcp = True if TCP/IP connections are allowed to this X server
# xserver-share = True if the X server is shared for both greeter and session
# xserver-hostname = Hostname of X server (only for type=xremote)
# xserver-display-number = Display number of X server (only for type=xremote)
# xdmcp-manager = XDMCP manager to connect to (implies xserver-allow-tcp=true)
# xdmcp-port = XDMCP UDP/IP port to communicate on
# xdmcp-key = Authentication key to use for XDM-AUTHENTICATION-1 (stored in keys.conf)
# greeter-session = Session to load for greeter
# greeter-hide-users = True to hide the user list
# greeter-allow-guest = True if the greeter should show a guest login option
# greeter-show-manual-login = True if the greeter should offer a manual login option
# greeter-show-remote-login = True if the greeter should offer a remote login option
# user-session = Session to load for users
# allow-user-switching = True if allowed to switch users
# allow-guest = True if guest login is allowed
# guest-session = Session to load for guests (overrides user-session)
# session-wrapper = Wrapper script to run session with
# greeter-wrapper = Wrapper script to run greeter with
# guest-wrapper = Wrapper script to run guest sessions with
# display-setup-script = Script to run when starting a greeter session (runs as root)
# display-stopped-script = Script to run after stopping the display server (runs as root)
# greeter-setup-script = Script to run when starting a greeter (runs as root)
# session-setup-script = Script to run when starting a user session (runs as root)
# session-cleanup-script = Script to run when quitting a user session (runs as root)
# autologin-guest = True to log in as guest by default
# autologin-user = User to log in with by default (overrides autologin-guest)
# autologin-user-timeout = Number of seconds to wait before loading default user
# autologin-session = Session to load for automatic login (overrides user-session)
# autologin-in-background = True if autologin session should not be immediately activated
# exit-on-failure = True if the daemon should exit if this seat fails
[Seat:*]
#type=local
#pam-service=lightdm
#pam-autologin-service=lightdm-autologin
#pam-greeter-service=lightdm-greeter
#xserver-command=X
#xmir-command=Xmir
#xserver-config=
#xserver-layout=
#xserver-allow-tcp=false
#xserver-share=true
#xserver-hostname=
#xserver-display-number=
#xdmcp-manager=
#xdmcp-port=177
#xdmcp-key=
greeter-session=lightdm-gtk-greeter
#greeter-hide-users=false
#greeter-allow-guest=true
#greeter-show-manual-login=false
#greeter-show-remote-login=true
user-session=xfce
#allow-user-switching=true
#allow-guest=true
#guest-session=
session-wrapper=/etc/lightdm/Xsession
#greeter-wrapper=
#guest-wrapper=
#display-setup-script=
#display-stopped-script=
#greeter-setup-script=
#session-setup-script=
#session-cleanup-script=
#autologin-guest=false
#autologin-user=
#autologin-user-timeout=0
#autologin-in-background=false
#autologin-session=
#exit-on-failure=false
# XDMCP Server configuration
# enabled = True if XDMCP connections should be allowed
# port = UDP/IP port to listen for connections on
# listen-address = Host/address to listen for XDMCP connections (use all addresses if not present)
# key = Authentication key to use for XDM-AUTHENTICATION-1 or blank to not use authentication (stored in keys.conf)
# hostname = Hostname to report to XDMCP clients (defaults to system hostname if unset)
# The authentication key is a 56 bit DES key specified in hex as 0xnnnnnnnnnnnnnn. Alternatively
# it can be a word and the first 7 characters are used as the key.
[XDMCPServer]
#enabled=false
#port=177
#listen-address=
#key=
#hostname=
# VNC Server configuration
# enabled = True if VNC connections should be allowed
# command = Command to run Xvnc server with
# port = TCP/IP port to listen for connections on
# listen-address = Host/address to listen for VNC connections (use all addresses if not present)
# width = Width of display to use
# height = Height of display to use
# depth = Color depth of display to use
[VNCServer]
#enabled=false
#command=Xvnc
#port=5900
#listen-address=
#width=1024
#height=768
#depth=8
After 90 seconds the blinking should stop. Then log in on vt and create a new nvidia-bug-report.log.
I wait about 5 mins but it not stop blink
please create a new nvidia-bug-report.log from recovery.
i can create a new nvidia-bug-report when I comment
on /etc/lightdm/lightdm.conf
nvidia-bug-report.log.gz (1.11 MB)
The xserver comes up correctly, so there’s really only a problem with lightdm running the xrandr commands. Is it possible to fetch /var/log/lightdm/lightdm.log from the ‘blinking’ nstate and attach it?
I willing to but I don’t know how to do this please help
Maybe there’s just something wrong with the script. Please post the output of
ls -l /etc/lightdm/display_setup.sh
and post the contents of it.
werterzz@werterzz:/media/werterzz/e4fd87c9-49cc-4ebf-b24a-3c17fd07e953/etc$ ls -l lightdm/display_setup.sh
-rwxr-xr-x 1 root root 78 Nov 15 10:27 lightdm/display_setup.sh
And what’s in it?
werterzz@werterzz:/media/werterzz/e4fd87c9-49cc-4ebf-b24a-3c17fd07e953/etc$ cat lightdm/display_setup.sh
#!/bin/sh
xrandr --setprovideroutputsource modesetting NVIDIA-0
xrandr --auto
Please change the script to
#!/bin/sh
xrandr --listproviders >>/var/log/lightdm/providers.txt 2>&1
xrandr --verbose >>/var/log/lightdm/providers.txt 2>&1
xrandr --setprovideroutputsource modesetting NVIDIA-0 >>/var/log/lightdm/providers.txt 2>&1
xrandr --auto >>/var/log/lightdm/providers.txt 2>&1
and check if the directory /var/log/lightdm exists.
Then enable the script again in lightdm config and post /var/log/lightdm/providers.txt when you have access to it again.
