providers.txt
http://paste.ubuntu.com/p/Q8ztYGmyS2/
Ok, looks like you’re running into a known bug with the amdgpu driver. Please change the script to
#!/bin/sh
xrandr --listproviders >>/var/log/lightdm/providers.txt 2>&1
xrandr --setprovideroutputsource modesetting NVIDIA-0 >>/var/log/lightdm/providers.txt 2>&1
xrandr --verbose >>/var/log/lightdm/providers.txt 2>&1
xrandr --auto >>/var/log/lightdm/providers.txt 2>&1
xrandr --output eDP-1-1 --auto >>/var/log/lightdm/providers.txt 2>&1
and try again, also post the file again.
Still getting the error
xrandr: Configure crtc 0 failed
Please try this:
#!/bin/sh
xrandr --output eDP-1-1 --set "PRIME Synchronization" "0" >>/var/log/lightdm/providers.txt 2>&1
xrandr --output eDP-1-1 --mode 0x46 >>/var/log/lightdm/providers.txt 2>&1
The xserver is just refusing to add the internal display. Please delete the file /usr/share/X11/xorg.conf.d/10-nvidia-drm-outputclass.conf
and check it changes anything.
Now my laptop blink about 5 sec and get stuck with cursor again that I can use terminal in it
Please create a new nvidia-bug-report.log in that state.
Great, now it’s not finding the glxserver_nvidia module, Manjaro sure has a strange kind of driver setup. Which driver package did you exactly install?
when I use mhwd -li I got
e[1me[31m> e[mInstalled PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-418xx 2019.10.25 false PCI
e[1me[31mWarning: e[mNo installed USB configs!
(that’s after i delete video-linux driver)
then I reboot it not work
then I tried to use pacman -Syuu
it update and upgrade all of packet
and when i reboot it got blinking screen again and i can’t access to terminal again
Please try reinstalling the nvidia driver package and check if the file
/usr/lib/xorg/modules/extensions/glxserver_nvidia
gets created afterwards. Otherwise ask Manjaro people where they put it.
now i can’t access manjaro terminal
Should I reinstall whole manjaro ?
In /usr/lib/xorg/modules/extensions/
I have libglx.so
I’ve downloaded and checked the Manjaro Nvidia driver packages and 418 seems to be some kind of compatibility package for older xservers and maybe bumblebee with some non-standard file layout. Please upgrade to the 440 driver, that’s a standard package.
installed video-nvidia-440xx
now i can access to terminal again
nvidia-bug-report.log.gz (1.09 MB)
Ok, now the driver layout looks fine but the config files the new manjaro package adds is telling me they’re favouring render offload. Please delete /etc/X11/xorg.conf and /etc/X11/xorg.conf.d/90-mhwd.conf and reboot. Then you should be able to run an application (no web-browsers currently) on the nvidia gpu by prepending __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia, e.g. from terminal
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia glxinfo | grep vendor
If that doesn’t work, please create a new nvidia-bug-report.log.
Logs look normal, you’ll also have to revert the changes you made to lightdm config.
Thanks for the info and answers. She was very helpful to me.
