Nvidia sample workload application on docker throwing error failed: unable to start container process: exec: "nvidia-smi"
I am trying to run Nvidia sample workload application on Nvidia jetson orin board.
After following the necessary installation steps i am getting below error while running the sample workload application on docker.
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: exec: “nvidia-smi”: executable file not found in $PATH: unknown.
Any idea what is might be missing?
Kernel:
Linux ubuntu-desktop 5.10.120-tegra #1 SMP PREEMPT Thu Oct 12 09:10:24 EDT 2023 aarch64 aarch64 aarch64 GNU/Linux
Hi, @gyanranjan.verma
This is the forum for cuda-gdb. You may need to ask more in Jetson related forum.
The steps you followed seems for desktop, not sure if the same steps for Jetson.
We start to support nvidia-smi from the JetPack 6.
If you are using JetPack 5, the tool is not available.
