I have a problem installing DRIVE OS 6.0.4 on my Drive Orin AGX.
I have followed the instructions, however the flash step fails.
This is the fail message in from the sdkmanager screen:
06:36:23 ERROR: Flash DRIVE OS - flash: command terminated with error 06:36:23 SUMMARY: Flash DRIVE OS - flash: First Error: Installation failed.
When I look into the log files, and grep for fail, i get this:
DRIVE_OS_6.0.4_SDK_Linux_replay.txt:2335:[ -e ${AURIX_PORT:-/dev/ttyACM1} ] || ( echo Failed to flash device: detected no board connected to host with USB cable. >&2 && false ) – I’m sure that I don’t have anything connected to the device and I also did reset the system.
I installed the Drive OS with SDK.
I had to put the system to recovery mode because in other hand the installation was failed. As soon as I put the system to recovery mode, everything installed smoothly.
Well, I’ll explain the behavior:
I have connected all USB cable to my host pc and did lsusb, I saw only 1 port, which was the debug port.
I have tried to install the device thru sdkmanager, but after 14% it failed, so it was clear that I don’t have communication for some reason.
Then I decided to boot the system to recovery mode, by turning it off and the holding the recovery button and turning on the device, then I saw another device in lsusb, which also prompted me to choose a device in step 1 in sdkmanager and I got installation finished in step 4.
