I just installed the sdk manager to be able to work with the jetson x2, the installation had no problem. but when executing in the terminal “sdkmanager” I get the following error:
/snapshot/main/node_modules/sql.js/js/sql.js:5
1<process.argv.length?process.argv[1].replace(/\/g,“/”):“unknown-program”);f.arguments=process.argv.slice(2);“undefined”!==typeof module&&(module.exports=f);process.on(“uncaughtException”,function(a){if(!(a instanceof ka))throw a;});f.inspect=function(){return"[Emscripten Module object]“}}else if(fa)f.print||(f.print=print),“undefined”!=typeof printErr&&(f.printErr=printErr),f.read=“undefined”!=typeof read?read:function(){throw"no read() available (jsc?)”;},f.readBinary=function(a){if(“function”===
^Error: EPERM: operation not permitted, unlink ‘/tmp/sdkmanager.sock’
at Object.unlinkSync (fs.js:1129:3)
at Socket. (/snapshot/main/headless.bundle.js)
at Socket.emit (events.js:315:20)
at emitErrorNT (internal/streams/destroy.js:92:8)
at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
at processTicksAndRejections (internal/process/task_queues.js:84:21) {
errno: -1,
syscall: ‘unlink’,
code: ‘EPERM’,
path: ‘/tmp/sdkmanager.sock’
Anyone have any idea how I can fix it?
