Nvidia-settings: Attribute GPUMemoryTransferRateOffsetAllPerformanceLevels (...) is not available
When running
nvidia-settings --verbose -a "GPUMemoryTransferRateOffsetAllPerformanceLevels=1270"
the command has no effect and I’m getting the following warning:
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:0].
See attached files for system configuration and log files.
Thank you in advance for your help.
Output from nvidia-settings:
WARNING: NV-CONTROL extension not present on screen 0 of this Display.
WARNING: Unable to determine number of NVIDIA Frame Lock Devices on ':0'.
WARNING: Unable to determine number of NVIDIA 3D Vision Pro Transceivers on ':0'.
WARNING: Unable to determine number of NVIDIA Display Devices on ':0'.
WARNING: Unable to determine number of NVIDIA X Screens on ':0'.
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:1].
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:2].
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:3].
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:4].
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:5].
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:6].
Output from nvidia-smi:
Tue Jan 26 00:22:11 2021
| NVIDIA-SMI 460.32.03    Driver Version: 460.32.03    CUDA Version: 11.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  GeForce GTX 1070    Off  | 00000000:01:00.0 Off |                  N/A |
|  0%   24C    P8     5W / 151W |      6MiB /  8119MiB |      0%      Default |
|                               |                      |                  N/A |
|   1  GeForce GTX 1070    Off  | 00000000:02:00.0 Off |                  N/A |
|  0%   28C    P8     7W / 180W |      6MiB /  8119MiB |      0%      Default |
|                               |                      |                  N/A |
|   2  GeForce GTX 1070    Off  | 00000000:03:00.0 Off |                  N/A |
|  0%   29C    P8     7W / 180W |      6MiB /  8119MiB |      0%      Default |
|                               |                      |                  N/A |
|   3  GeForce GTX 1070    Off  | 00000000:06:00.0 Off |                  N/A |
|  0%   27C    P8     4W / 151W |      6MiB /  8119MiB |      0%      Default |
|                               |                      |                  N/A |
|   4  GeForce GTX 1070    Off  | 00000000:07:00.0 Off |                  N/A |
|  0%   20C    P8     4W / 151W |      6MiB /  8119MiB |      0%      Default |
|                               |                      |                  N/A |
|   5  GeForce GTX 1070    Off  | 00000000:09:00.0 Off |                  N/A |
|  0%   31C    P8     7W / 180W |      6MiB /  8119MiB |      0%      Default |
|                               |                      |                  N/A |
|   6  GeForce GTX 1070    Off  | 00000000:0A:00.0 Off |                  N/A |
|  0%   29C    P8     4W / 151W |      6MiB /  8119MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      1042      G   /usr/libexec/Xorg                   4MiB |
|    1   N/A  N/A      1042      G   /usr/libexec/Xorg                   4MiB |
|    2   N/A  N/A      1042      G   /usr/libexec/Xorg                   4MiB |
|    3   N/A  N/A      1042      G   /usr/libexec/Xorg                   4MiB |
|    4   N/A  N/A      1042      G   /usr/libexec/Xorg                   4MiB |
|    5   N/A  N/A      1042      G   /usr/libexec/Xorg                   4MiB |
|    6   N/A  N/A      1042      G   /usr/libexec/Xorg                   4MiB |
Output of lspci:
00:00.0 Host bridge: Intel Corporation 8th Gen Core 4-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] (rev 08)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 08)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 630
00:14.0 USB controller: Intel Corporation 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller
00:16.0 Communication controller: Intel Corporation 200 Series PCH CSME HECI #1
00:17.0 SATA controller: Intel Corporation 200 Series PCH SATA controller [AHCI mode]
00:1b.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #17 (rev f0)
00:1b.4 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #21 (rev f0)
00:1c.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #1 (rev f0)
00:1c.3 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #4 (rev f0)
00:1c.4 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #5 (rev f0)
00:1c.5 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #6 (rev f0)
00:1c.6 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #7 (rev f0)
00:1c.7 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #8 (rev f0)
00:1d.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #9 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Z370 Chipset LPC/eSPI Controller
00:1f.2 Memory controller: Intel Corporation 200 Series/Z370 Chipset Family Power Management Controller
00:1f.3 Audio device: Intel Corporation 200 Series PCH HD Audio
00:1f.4 SMBus: Intel Corporation 200 Series/Z370 Chipset Family SMBus Controller
01:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
02:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
02:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
03:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
03:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
06:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
06:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
07:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
07:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
09:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
09:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
0a:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
0a:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
Installed packages:
Installed Packages
akmod-nvidia.x86_64                       3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
kmod-nvidia-5.10.7-200.fc33.x86_64.x86_64 3:460.32.03-1.fc33 @@commandline
kmod-nvidia-5.10.9-201.fc33.x86_64.x86_64 3:460.32.03-1.fc33 @@commandline
kmod-nvidia-5.9.16-200.fc33.x86_64.x86_64 3:460.32.03-1.fc33 @@commandline
nvidia-persistenced.x86_64                3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
nvidia-settings.x86_64                    3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
nvidia-xconfig.x86_64                     3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
xorg-x11-drv-nvidia.x86_64                3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
xorg-x11-drv-nvidia-cuda.x86_64           3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
xorg-x11-drv-nvidia-cuda-libs.x86_64      3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
xorg-x11-drv-nvidia-devel.x86_64          3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
xorg-x11-drv-nvidia-kmodsrc.x86_64        3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
xorg-x11-drv-nvidia-libs.x86_64           3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
boot.log (218.1 KB)
xorg.conf (2.0 KB)
Xorg.0.log (175.7 KB)
