Nvidia-smi command stuck (process state is D)
System: debian12
GPU: RTX 3090
Driver Version: 550.54.14
nvidia-smi stacktrace:
[<0>] nvidia_open+0x2a4/0x4b0 [nvidia]
[<0>] chrdev_open+0xc1/0x250
[<0>] do_dentry_open+0x1e2/0x410
[<0>] path_openat+0xb7d/0x1260
[<0>] do_filp_open+0xaf/0x160
[<0>] do_sys_openat2+0xaf/0x170
[<0>] __x64_sys_openat+0x6a/0xa0
[<0>] do_syscall_64+0x58/0xc0
[<0>] entry_SYSCALL_64_after_hwframe+0x64/0xce
nvidia-bug-report.log.gz (261.4 KB)
nvidia-bug-report also stuck:
nvidia-bug-report.sh will now collect information about your
system and create the file 'nvidia-bug-report.log.gz' in the current
directory.  It may take several seconds to run.  In some
cases, it may hang trying to capture data generated dynamically
by the Linux kernel and/or the NVIDIA kernel module.  While
the bug report log file will be incomplete if this happens, it
may still contain enough data to diagnose your problem.
If nvidia-bug-report.sh hangs, consider running with the --safe-mode
and --extra-system-data command line arguments.
Please include the 'nvidia-bug-report.log.gz' log file when reporting
your bug via the NVIDIA Linux forum (see forums.developer.nvidia.com)
or by sending email to 'linux-bugs@nvidia.com'.
By delivering 'nvidia-bug-report.log.gz' to NVIDIA, you acknowledge
and agree that personal information may inadvertently be included in
the output.  Notwithstanding the foregoing, NVIDIA will use the
output only for the purpose of investigating your reported issue.
Running nvidia-bug-report.sh...
