Hi all,
I’m using with satisfaction CUDA to transcoding tv registrations. I’m trying to configure my system with a 2nd Gpu to increase the performance, but I have a big problem. The system don’t recognize the 2nd Gpu. The Gpu are two GTX1050Ti 4GB
this is the output of nvidia-smi command:
I’m using Ubuntu 20.04.02 LTS with kernel 5.8.0-43-generic and as you can see driver version is 460.27.04 and CUDA Version: 11.2
Following the solutions proposed in others topics, I had launched the following commands and I post the results
lspci |grep -i nv
01:00.0 VGA compatible controller: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
04:00.0 VGA compatible controller: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] (rev a1)
04:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
#dmesg |grep NVRM
[ 671.241183] NVRM: request_mem_region failed for 0M @ 0x0. This can
NVRM: occur when a driver such as rivatv is loaded and claims
NVRM: ownership of the device’s registers.
[ 671.241191] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 671.241191] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 460.27.04 Fri Dec 11 23:35:05 UTC 2020
nvidia-xconfig --query-gpu-info
Number of GPUs: 1
GPU #0:
Name : GeForce GTX 1050 Ti
UUID : GPU-407c136c-8177-c6c4-509c-1b15dcbf6cbb
PCI BusID : PCI:1:0:0
Number of Display Devices: 1
Display Device 0 (TV-1):
EDID Name : AGO
Minimum HorizSync : 31.469 kHz
Maximum HorizSync : 67.500 kHz
Minimum VertRefresh : 59 Hz
Maximum VertRefresh : 60 Hz
Maximum PixelClock : 148.500 MHz
Maximum Width : 1920 pixels
Maximum Height : 1080 pixels
Preferred Width : 1024 pixels
Preferred Height : 768 pixels
Preferred VertRefresh : 60 Hz
Physical Width : 300 mm
Physical Height : 230 mm
The problem is securely into the NVRM message, but I’m not able to find a solutions. The nouveau driver are blacklisted with file /etc/modprobe.d/blacklist-nvidia-nouveau.conf other driver also blacklisted (but editing the /etc/modprobe.d/blacklist.conf ) are vga16fb rivafb nvidiafb rivatv
Any help will be many appreaced.
Thank you
