Hi
For installation of gromacs in Tesla C2050 workstation, with recommendation of CUDA 8.0 [Which recent cuda + gromacs versions combo suitable for Tesla C2050 workstation - User discussions - GROMACS forums] (Which recent cuda + gromacs versions combo suitable for Tesla C2050 workstation - User discussions - GROMACS forums) . was installed
cuda_8.0.61_375.26_linux-run
and set the path in the .bashrc
export PATH=/usr/local/cuda-8.0/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-8.0/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
rebooted and tried
nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
kindly let me know if anything miss mention and please guide solve this issue
Thank you
checked following things
nvcc --version
Copyright (c) 2005-2016 NVIDIA Corporation
Built on Tue_Jan_10_13:22:03_CST_2017
Cuda compilation tools, release 8.0, V8.0.61
gcc --version
gcc (GCC) 9.4.0
Copyright (C) 2019 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
lshw -C display
sudo lshw -C display
*-display UNCLAIMED
description: VGA compatible controller
product: GF100GL [Tesla C2050 / C2070]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:84:00.0
version: a3
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list
configuration: latency=0
resources: memory:f8000000-f9ffffff memory:dc000000-dfffffff memory:d8000000-dbffffff ioport:ec00(size=128) memory:f7f80000-f7ffffff
lspci | grep -i nvidia
84:00.0 VGA compatible controller: NVIDIA Corporation GF100GL [Tesla C2050 / C2070] (rev a3)
84:00.1 Audio device: NVIDIA Corporation GF100 High Definition Audio Controller (rev a1)
cat /etc/*-release | head -n 1
CentOS Linux release 7.9.2009 (Core)
uname -r
3.10.0-1160.36.2.el7.x86_64
sudo yum install kernel-devel epel-release dkms
Package kernel-devel-3.10.0-1160.45.1.el7.x86_64 already installed and latest version
Package epel-release-7-14.noarch already installed and latest version
Package dkms-2.8.6-1.el7.noarch already installed and latest version
