Please help!
Trying to get nvidia-smi to find my nvidia 1660 gpu (driver version 525.78.01) on Ubuntu 22.04.1 LTS headless server. I am using the card for plex transcodes.
Is there a way to tell nvidia-smi where to look?
Secure boot is turned on in the bios (I was warned that turning it off at this point can result in a major PIA)
Let me know what other info might help.
nvidia-bug-report.log.gz (192.8 KB)
Stuff I have done
I have tried every solution I could find online that looked like it had a remote chance of helping out:
-installed legacy drivers
Re-installed latest drivers, from ubuntu repository and nvidia drivers from the site
Editing X-windows related configuration files per articles found just in case
- Adding these parameters to grub one by one per the readme file:*pci=noacpi* *pci=biosirq* *noapic* *acpi=off*
Created a .conf file in /etc/modprobe.d with:
blacklist nouveau
options nouveau modeset=0
And just in case another .conf file with:
options nvidia “NVreg_RestrictProfilingToAdminUsers=0”
dmesg |grep nv
[ 0.320062] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.398483] rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.086785] with environment:
[ 1.283888] nvidia: loading out-of-tree module taints kernel.
[ 1.300809] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 1.308874] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[ 1.309744] nvidia 0000:01:00.0: enabling device (0000 → 0003)
[ 1.309821] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 1.715595] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 525.78.01 Release Build (dvs-builder@U16-J11-10-2) Mon Dec 26 05:39:32 UTC 2022
[ 1.718436] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 3.375726] NVRM: Open nvidia.ko is only ready for use on Data Center GPUs.
[ 3.375727] NVRM: To force use of Open nvidia.ko on other GPUs, see the
[ 3.665037] [drm:nv_drm_load [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NvKmsKapiDevice
[ 3.665171] [drm:nv_drm_probe_devices [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to register device
[ 6.139685] nvidia-uvm: Loaded the UVM driver, major device number 510.
[ 8.037192] nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
[ 10.817452] audit: type=1400 audit(1674946209.914:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=817 comm=“apparmor_parser”
[ 10.817456] audit: type=1400 audit(1674946209.914:4): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=817 comm=“apparmor_parser”
[ 281.206744] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:306
[ 281.206755] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:306
lspci -vvv sees the card:
01:00.0 VGA compatible controller: NVIDIA Corporation TU116 [GeForce GTX 1660] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. TU116 [GeForce GTX 1660]
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 16
Region 0: Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at e0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at f0000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at e000 [size=128]
Expansion ROM at f7000000 [virtual] [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [78] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <512ns, L1 <16us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s (downgraded), Width x16 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range AB, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp- 10BitTagReq- OBFF Via message, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ OBFF Disabled,
AtomicOpsCtl: ReqEn-
LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+ EqualizationPhase1+
EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [250 v1] Latency Tolerance Reporting
Max snoop latency: 34326183936ns
Max no snoop latency: 34326183936ns
Capabilities: [258 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=255us PortTPowerOnTime=10us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=10us
Capabilities: [128 v1] Power Budgeting <?>
Capabilities: [420 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn- PerformEqu-
LaneErrStat: 0
Capabilities: [bb0 v1] Physical Resizable BAR
BAR 0: current size: 16MB, supported: 16MB
BAR 1: current size: 256MB, supported: 64MB 128MB 256MB
BAR 3: current size: 32MB, supported: 32MB
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
Thank you!
