Having the same problem with GTX 1650. Tried to run it on Debian 10 and on Ubuntu 20.
Debian 10, on standard and experimental kernel. 440 and 450 drivers. No luck.
Now I am trying to get it working on Ubuntu with drivers 450 included in Ubuntu repos. Still no luck. Everything was done on fresh installs. Below some outputs from commands:
lspci -vvv
> 22:00.0 VGA compatible controller: NVIDIA Corporation TU117 [GeForce GTX 1650] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] TU117 [GeForce GTX 1650] Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0 Interrupt: pin A routed to IRQ 175 NUMA node: 1 Region 0: Memory at d9000000 (32-bit, non-prefetchable) [size=16M] Region 1: Memory at 3c000000000 (64-bit, prefetchable) [size=256M] Region 3: Memory at 3c010000000 (64-bit, prefetchable) [size=32M] Region 5: I/O ports at 6000 [size=128] Expansion ROM at daf00000 [virtual] [disabled] [size=512K] Capabilities: [60] Power Management version 3 Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+) Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME- Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+ Address: 0000000000000000 Data: 0000 Capabilities: [78] Express (v2) Legacy Endpoint, MSI 00 DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ DevCtl: CorrErr- NonFatalErr+ FatalErr+ UnsupReq+ RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset- MaxPayload 256 bytes, MaxReadReq 512 bytes DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend- LnkCap: Port #0, Speed 8GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+ LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+ ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt- LnkSta: Speed 2.5GT/s (downgraded), Width x16 (ok) TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt- DevCap2: Completion Timeout: Range AB, TimeoutDis+, NROPrPrP-, LTR- 10BitTagComp-, 10BitTagReq-, OBFF Via message, ExtFmt-, EETLPPrefix- EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit- FRS- AtomicOpsCap: 32bit- 64bit- 128bitCAS- DevCtl2: Completion Timeout: 65ms to 210ms, TimeoutDis-, LTR-, OBFF Disabled AtomicOpsCtl: ReqEn- LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis- Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS- Compliance De-emphasis: -6dB LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+ EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest- Capabilities: [100 v1] Virtual Channel Caps: LPEVC=0 RefClk=100ns PATEntryBits=1 Arb: Fixed- WRR32- WRR64- WRR128- Ctrl: ArbSelect=Fixed Status: InProgress- VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans- Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256- Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff Status: NegoPending- InProgress- Capabilities: [258 v1] L1 PM Substates L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+ PortCommonModeRestoreTime=255us PortTPowerOnTime=10us L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1- T_CommonMode=0us LTR1.2_Threshold=0ns L1SubCtl2: T_PwrOn=10us Capabilities: [128 v1] Power Budgeting <?> Capabilities: [420 v2] Advanced Error Reporting UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- > MalfTLP- ECRC- UnsupReq- ACSViol- UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt+ UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol- UESvrt: DLP+ SDES+ TLP+ FCP+ CmpltTO+ CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol- CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr- CEMsk: RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ AdvNonFatalErr+ AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn- MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap- HeaderLog: 00000000 00000000 00000000 00000000 Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?> Capabilities: [900 v1] Secondary PCI Express LnkCtl3: LnkEquIntrruptEn-, PerformEqu- LaneErrStat: 0 Capabilities: [bb0 v1] Resizable BAR <?> Kernel driver in use: nvidia Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
dmesg | grep NVRM
[ 5.865440] NVRM : loading NVIDIA UNIX x86_64 Kernel Module 450.66 Wed Aug 12 19:42:48 UTC 2020
[ 101.738202] NVRM : GPU 0000:22:00.0: RmInitAdapter failed! (0x26:0xffff:1266)
[ 101.738300] NVRM : GPU 0000:22:00.0: rm_init_adapter failed, device minor number 0
[ 885.973227] NVRM : GPU 0000:22:00.0: RmInitAdapter failed! (0x26:0xffff:1266)
[ 885.973319] NVRM : GPU 0000:22:00.0: rm_init_adapter failed, device minor number 0
[ 942.341436] NVRM : GPU 0000:22:00.0: RmInitAdapter failed! (0x26:0xffff:1266)
[ 942.341481] NVRM : GPU 0000:22:00.0: rm_init_adapter failed, device minor number 0
[ 1403.988729] NVRM : GPU 0000:22:00.0: RmInitAdapter failed! (0x26:0xffff:1266)
[ 1403.988775] NVRM : GPU 0000:22:00.0: rm_init_adapter failed, device minor number 0
[ 1419.358018] NVRM : GPU 0000:22:00.0: RmInitAdapter failed! (0x26:0xffff:1266)
[ 1419.358105] NVRM : GPU 0000:22:00.0: rm_init_adapter failed, device minor number 0
lsmod | grep nvidia
nvidia_uvm 1007616 0
nvidia_drm 53248 0
nvidia_modeset 1183744 1 nvidia_drm
nvidia 19701760 2 nvidia_uvm,nvidia_modeset
drm_kms_helper 184320 4 mgag200,nvidia_drm
drm 491520 6 drm_kms_helper,drm_vram_helper,mgag200,nvidia_drm,ttm
debian_dell_440.log.gz (554.8 KB)
ubuntu_dell_450.log.gz (108.6 KB)
