nvidia-smi show no device found.
Verified the following to be fine. I have an image with commands and output and unfortunately i am not able to attach it and the debug bundle.
- The driver being installed
- The N*470.182.03.run file used to deploy
- noueaue being disabled
- No secure boot
- nvidia-smi showing no device.
Could someone help here.
I have the same Issue with an other legacy graphics card. Tesla K80 detected on OpenSuse 15.5, but nvidia-smi couldn't communicate with the NVIDIA driver . I was not able to get mine working yet, but I know you definitively did not share another data to debug your problem. What stops you from uploading the debug file here? For me it was just drag and drop.
nvidia-bug-report.log.gz (552.9 KB)
@ben.kinigadner Thanks. The drag and drop worked. I was looking for attachment icon.
dmesg:
[ 555.722287] NVRM: GPU 0000:43:00.0: GPU does not have the necessary power cables connected.
[ 555.722980] NVRM: GPU 0000:43:00.0: RmInitAdapter failed! (0x24:0x1c:1211)
[ 555.723094] NVRM: GPU 0000:43:00.0: rm_init_adapter failed, device minor number 0
[ 558.665969] NVRM: GPU 0000:43:00.0: GPU does not have the necessary power cables connected.
[ 558.666470] NVRM: GPU 0000:43:00.0: RmInitAdapter failed! (0x24:0x1c:1211)
[ 558.666579] NVRM: GPU 0000:43:00.0: rm_init_adapter failed, device minor number 0
We don’t have the same problem, but this looks like there is a problem with the power.
@ben.kinigadner K4000 does not need any external power. So, this error msg does not point to the any corrective action that can be taken.
VIDIA GLX Module 470.182.03 Fri Feb 24 03:21:43 UTC 2023
[ 3292.037] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 3297.928] (EE) NVIDIA(GPU-0): The NVIDIA GPU at PCI:67:0:0 does not have the necessary
[ 3297.928] (EE) NVIDIA(GPU-0): external power cables attached; X cannot use this GPU
[ 3297.928] (EE) NVIDIA(GPU-0): until the problem is rectified. Please shut down your
[ 3297.928] (EE) NVIDIA(GPU-0): computer, open its case, and attach all of the appropriate
[ 3297.928] (EE) NVIDIA(GPU-0): power connectors. Please see the documentation provided
[ 3297.928] (EE) NVIDIA(GPU-0): with your NVIDIA GPU for more details.
[ 3297.928] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[ 3297.928] (EE) NVIDIA(G0): Failing initialization of X screen
GLX thinks it should have one, I don’t know how these cards work, but maybe there is a way do manipulate how much power these cards get?
@ben.kinigadner I don’t have a power outlet in my Dell T620 feed to the GPU connector. I will check what else can be done. Thanks for your help.
