Nvidia-smi output: No devices were found
I need some help on installing my 2080TI GPU with Linux 18.04.5.4-100-generic.
I have successful stopped Nouveau and am now running Nvidia driver kernel.
lspci -vvv:
06:00.0 VGA compatible controller: NVIDIA Corporation Device 1e04 (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 3711
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 17
Region 0: Memory at a2000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at 90000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at a0000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at 4000 [size=128]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities:
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
But nvidia-smi:
dmesg | grep NVRM:
[ 3.914460] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.103.01 Thu Jan 6 12:10:04 UTC 2022
[ 4.755445] NVRM: GPU 0000:06:00.0: RmInitAdapter failed! (0x26:0x56:1253)
[ 4.755518] NVRM: GPU 0000:06:00.0: rm_init_adapter failed, device minor number 0
I have been fighting with this for the past week straight any help or direction would be super appreciated.
nvidia-bug-report.log.gz (178.4 KB)
Figured it. Nvidia driver 470 is broken with 18.04-5.4-100-generic and a 2080ti GPU card.
Use the softer update tool in Linux go to additional drivers tab and switch to 450 driver.
