Nvidia-smi problem
The system:
Distributor ID: Kali
Description: Kali GNU/Linux Rolling
Release: 2019.4
Codename: kali-rolling
The GPU is 820m hybrid i.e optimus so I have installed legacy drivers 390.xx as seen in the output below.
The drivers were installed using the commands
apt-get install nvidia-legacy-390xx-driver
apt-get install nvidia-legacy-390xx-smi
apt-get install nvidia-legacy-390xx-opencl-icd
I have disabled nouveau
Now coming to the question, as mentioned in kali linux here Install NVIDIA GPU Drivers | Kali Linux Documentation
the output of nvidia-smi is different since my Pwr is N/A so what could be the possible problem.
| NVIDIA-SMI 390.132 Driver Version: 390.132 |
| 0 GeForce 820M Off | 00000000:09:00.0 N/A | N/A |
| N/A 54C P0 N/A / N/A | 0MiB / 1985MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
Power management and other things are not supported on most low end gpus. So just ignore the ‘N/A’ and ‘Not supported’ entries.
Since you have an optimus notebook, you’ll have to set it up to use PRIME:
https://devtalk.nvidia.com/default/topic/1022670/linux/official-driver-384-59-with-geforce-1050m-doesn-t-work-on-opensuse-tumbleweed-kde/post/5203910/#5203910
