Nvidia-smi works but no graphics display on Rhel9
nvidia-bug-report.log.gz (391.8 KB)
Hello!
I recently installed my nvidia drivers to my Rhel9 instance and my nvidia-smi works, however the GPU will not output display. I am also able to use the GPU for Pytorch/Cuda training so the system certainly can access it.
One display is through HDMI and the other is Display Port, neither works through GPU but will through CPU. I know the GPU should work because the system is a dual boot and the GPU will output display on windows.
Thank you!
Bump, I’ve had a few people message me directly with the same issue though I don’t have a fix. Is this a known issue? Thank you everybody for your help!
In case someone encounters the same issue
My issues resolved themselves, I just turned it on one day and the display worked. I did not download anything new or make any configuration changes. I wonder if some of these drivers just need the machine to reboot a couple of times for the changes to take? Unsure. Sorry, it’s not very helpful, that’s all the information I have.
