NVIDIA Software update Bricked my 2 Sparks
I am sure there is a thread somewhere already on this topic that I am not finding.
My recent update to my Nvidia Sparks bricked both of them, requiring a complete re-install. I wanted to express my deep disappointment in Nvidia to have delivered such a broken update. I expect alot more from Nvidia, I expect excellence, not crap.
I lost several hours of engineering time, trying to recover and ultimately had to do a complete re-install. My disappointment has pointed me to reserve two of the upcoming AMD AI boxes, as an alternative platform.
A multi-trillion dollar company like Nvidia should have the engineering resources to deliver a quality product, which brings in to question how serious Nvidia is about the Spark platform.
As someone who has been a huge supporter, and a stock holder of Nvidia for years, this was not easy to say. My hope is that the engineering leadership gets their Sh_t together.
Ok back to my regularly scheduled program.
Sorry to hear that you lost so much time. Out of curiosity, did it happen over their web UI update (over default port 11000) or a manual one? The web-UI update is running some extra steps on top of simple updates to ensure (in theory) that firmware updates are actually applied. It will be useful for us all to know if it was a bug in the web-UI itself.
It was from the Web UI update. Very frustrating, I see on the web a reference to this issue. When I get an update from Nvidia I used to have a high degree of confidence, not anymore unfortunately.
Stuff happens :-)
Thanks for the info.
Thank you for reporting this, and I’m sorry to hear the update left both of your systems in that state.
Since you confirmed this happened through the Web UI / DGX Dashboard update path, we’d like to gather a bit more detail so we can narrow down whether this was a dashboard-triggered update issue, a package/firmware update failure, or a recovery-state problem.
If possible, could you please share the following for one of the affected systems:
  1. The DGX Spark software version before the update, if you remember it
  2. Whether the failure happened during install, after reboot, or on the next boot
  3. What “bricked” looked like specifically:
    • no boot
    • boot loop
    • stuck in UEFI / recovery
    • OS booted but services/UI were broken
  4. Whether you saw any error message in the Dashboard or on-screen during reboot
  5. Whether both systems were on the same starting version and followed the same update path
If you still have any logs or screenshots from the failed state, those would be especially helpful.
For reference, the official update path is through DGX Dashboard, and the recovery procedure is documented here:
Thank you again for the report. We’re investigating this as a potential software update issue and will update the thread once we have more information.
Just chiming in to say I am experiencing the exact same issue. I have a ThinkStation DGX and after applying the update, absolutely nothing works anymore.
An attached monitor just shows a completely black screen, and the device has been completely unresponsive and off the network for about 45 minutes now. I am really fearing the worst here.
Has there been any update from the engineering team on a fix that doesn’t require a complete reinstall?
Hi Tobias,
Welcome to the community and thanks for your feedback. The OP had a DGX Spark and was doing the update via Web UI. Can you confirm you’re not using a DGX Spark but rather a Lenovo ThinkStation DGX? How was the update initialized in your case? Any logs or additional details would be helpful.
Thanks,
Neill
Hi Neill,
Thanks for getting back to me so quickly!
Yes, I can confirm that I am using a Lenovo ThinkStation DGX.
Regarding the process: I initiated the update via the Web UI. The server was originally running in headless mode. When it dropped off the network and nothing worked anymore, I hooked up a monitor, keyboard, and mouse.
The monitor remained completely black, and trying to switch to a text console (Ctrl+Alt+F2, F3, etc.) didn’t trigger any response. The only sign of life was the Num Lock key toggling. I performed a hard reset, which thankfully triggered a normal reboot.
The system is currently stable and back on the network. Interestingly, the dashboard is still offering me updates, including a firmware upgrade.
UPDATE: Interestingly, the previous batch of updates is no longer showing up in the dashboard. It is now only offering me one single upgrade: UEFI Device Firmware (from 0.5.0 to 0.5.7).
However, given this experience, I think I will hold off on applying them for now! ;-)
I haven’t extracted any logs yet since I was just relieved it booted up again. Are there any specific log files or system reports you would like me to pull to help your team investigate this?
Thanks again for looking into this!
Best, Tobias
UPDATE:
Hi Neill,
I managed to log directly into the machine and pulled the /var/log/apt/history.log. It sheds a lot of light on what happened.
The Web UI triggered an aptdaemon upgrade that installed a major kernel update (linux-image-nvidia-hwe-24.04, version 6.17.0-1026) along with new NVIDIA drivers (linux-modules-nvidia-580-open...).
According to the log, the apt transaction actually completed successfully, showing an End-Date of 13:43:48. This aligns perfectly with the system dropping off the network around 13:44. It appears the system hung immediately after the package installation finished—most likely during a kernel module reload or when the Web UI attempted to reboot the machine with the newly installed display/network drivers while it was in headless mode.
Would you like me to pull the journalctl -b -1 logs from that specific timeframe so your team can see the exact kernel panic or hang that occurred post-installation?
Best, Tobias
LAST UPDATE AND INFO:
Hi Neill,
I pulled the journalctl -b -1 logs and it perfectly explains the behavior. The system didn’t crash during the update – the Web UI successfully triggered a reboot at 13:44:17, and the OS shut down cleanly.
However, the system completely hung at the very last step of the reboot sequence (the ACPI / hardware power cycle handoff). The logs show a normal shutdown sequence reaching reboot.target and Finished systemd-reboot.service. Right before the journal stops, there is a kernel message: watchdog: watchdog0: watchdog did not stop!, followed by fbcon: Taking over console and Syncing filesystems and block devices.
At this point, the journal stops, but the physical reboot never happened. The machine just sat there in this limbo state with a black screen (since display drivers were unloaded) but with a responsive kernel (Num Lock still working) until I forced the hard reset 45 minutes later.
I realize my experience might differ slightly from the original poster’s, as my system didn’t end up fully “bricked” but rather hung during the reboot phase. Still, I hope these logs are useful for your investigation into the Web UI update process.
It seems the Web UI update process has an issue with successfully triggering the actual hardware reboot on the ThinkStation DGX after the apt packages finish installing. Let me know if you need the raw text output or any other logs!
Best, Tobias
Hi @tobias.frey,
Thank you for the detailed log analysis, this was really crucial in helping us to understand what’s happening.
What your logs show: The apt transaction completed successfully. The hang occurred during the subsequent reboot, not during package installation itself. The watchdog0: watchdog did not stop! message you saw is a known cosmetic message on DGX Spark during reboots — it’s generally benign when the system cycles normally. The issue in your case is that the reboot didn’t complete: fbcon: Taking over console is the last journal entry, which indicates the system handed off to the framebuffer console and then stalled before finishing the boot sequence. The hard power cycle was the correct recovery action.
On the pending UEFI firmware update (0.5.0 → 0.5.7): I understand the hesitation given what just happened. When you’re ready to apply it, a few things that may help:
  • Connect a monitor and keyboard before starting the update so you can observe the post-reboot state directly
  • The system may appear unresponsive at a black screen for an extended period (30–45 minutes is not unusual for firmware-level updates) — this is worth waiting out before concluding something is wrong
  • If it’s still unresponsive after that window, a hard power cycle is a safe recovery step, same as before
One ask: If you’re willing, the most useful artifact for our investigation would be the journal from the update session itself. After your next reboot (whether after the UEFI update or otherwise), you can capture it with:
sudo journalctl -b -1 --no-pager > journal_previous_boot.txt
That log from the session that hung would help us pinpoint exactly where in the boot sequence the stall is occurring and whether it’s consistent across systems.
Glad to hear your system is stable and back on the network. Let me know if you run into anything else.
@esvehla if you have any feedback, or further details to share, they are welcomed as well.
I also have a ThinkStation PGX and experienced the same issue.
On the ThinkStation PGX, firmware updates do not work when initiated over SSH.
I can also confirm that if you log in directly to the ThinkStation PGX and run the firmware update locally (instead of over SSH), the firmware update completes successfully without any issues.
On Lenovo, you have to update from DGX OS using the firmware update tool, not from the DGX dashboard. You can’t update to the latest version one at a time; this happened to me with the power adapter firmware.
Here is my article about how I fixed my DGX Spark update failures. Hope it helpful.
https://medium.com/@sannminwin/my-nvidia-dgx-spark-became-a-brick-after-an-update-heres-how-i-brought-it-back-without-bfac7e1f2780
@tobias.frey Circling back on this, should any logs be available as requested, that would be supremely helpful. Our teams are actively working on this issue and have circled back persistently to confirm if we can get the full log. Even a confirmation that the same is definitely not available would help move things forward.
@esvehla Your feedback is also highly sought after by our engineering teams trying as well (see above for details). If you happen to have any logs preserved, please circle back and let us know. Rest assured, we’re doing everything we can to avoid this kind of experience for our customers. Sorry again about the update challanges.
Hi everyone,
Just a quick update: I have exported the requested logs and sent them directly to @zneill via Direct Message for security reasons. The logs cover the period from July 4th up to today, so they also include the successful updates I recently performed.
I also want to mention that in the meantime, I was able to successfully install all pending updates. I want to explicitly emphasize that I did these updates directly via the DGX dashboard. I know another user mentioned earlier in this thread that the DGX dashboard is not the correct way to update specifically for the Lenovo ThinkStation PGX, but for me, exactly this method worked flawlessly without any issues.
Given the confusion around this, I would really appreciate an official statement or clear documentation from Lenovo clarifying the correct and supported update procedure for the ThinkStation PGX.
Hope this helps anyone else facing similar challenges!
Looks like my fingers had a mind of their own earlier. I meant to say Lenovo ThinkStation DGX, not PGX! I guess I was just too excited that the updates finally worked. 😂
Anyway, it’s a DGX!
In fact, Lenovo calls it “Thinkstation PGX”.
I have two of them and both updated completely and flawlessly using the DGX Dashboard. I recommend to use a screen connected via HDMI because screens connected only via USB-C usually stay dark during the firmware updates (which take quit long) - so you have no idea if it still working…
On Lenovo Thinkstation PGX, the BIOS needs to be upgraded to version 0DA or higher in order to support the FW upgrade without a display. You can download the latest version, OEA, from the Lenovo website
