NVIDIA Support Failed Me..can someone help?
I have four DGX Spark Founders Editions, all the same board revision (P4242 A04). When the USB-C PD controller update to 0x00000516 came through, three of them took it without a problem. The fourth didn’t.
On the bad unit, the BIOS firmware page now shows PD0 FW1 at 0.0. The other three show 5.22 on that bank. Everything else (FLASH, UEFI, EC) matches across all four.
The odd part is that the system thinks the update worked. ESRT logs it as a success, but fwupd reports the version never changed:
failed to run update on reboot: expected 0x00000516 and got 0x0000040a
There’s also no UEFI capsule result for any of the PD attempts, even though the EC and SoC updates applied that same day are logged normally.
I tried it three times in total, including two full power-offs with AC pulled for over a minute. Same result each time, and one of those boots took about 100 seconds instead of the usual 35. I’ve stopped trying because PD0 is running on its only good bank now and I don’t want to risk that one too.
The unit itself seems fine. Field Diagnostics passes, it runs full GPU load without throttling, and I haven’t seen any power or USB-C issues. (I ran fieldiag 1.0.9-1 because 2.0.4-1 wants ofed-scripts/doca-ofed, and this unit is half of a RoCE pair, so I didn’t want to touch the networking stack.)
Two questions:
1. Has anyone else ended up with a 0.0 PD bank after this update? If you found a way to recover it, I’d like to hear how.
2. For the NVIDIA folks here: I opened a Customer Care case on October 3 (261003-000005, serial 1983925020107) and sent everything I was asked for the same day: diagnostics, fwupd and dmidecode output, BIOS photos, and the dashboard screenshot. Support confirmed the firmware history shows a failed update. Since then I haven’t gotten an actual answer. One reply was clearly meant for a different customer (it was about a Windows driver install), and the next said the case was being escalated. I’ve followed up twice since then with nothing back.
I’m not trying to bash support, but I’m stuck. I’ve done every troubleshooting step I was asked to do and I can’t get an answer on what happens next. Could someone on the Spark team look at this and tell me whether it qualifies for an RMA, or whether there’s a supported way to rewrite the bank? Happy to post the full logs here if that helps.
Hi @robert318 — thanks for the detail here, and sorry for the run-around on the case. A reply meant for a different customer isn’t what you should have gotten.
Straight answer on your two questions: I can’t tell you whether this qualifies for an RMA, or whether there’s a supported way to rewrite the bank. I’m not going to guess at either in public when you’ve already had one wrong answer.
What I can say is that the picture may not be settled yet. Could you post:
sudo dmidecode -t 45 | grep -C 4 PD
The BIOS firmware page doesn’t show everything. That command gives FW1 and FW2 for both PD0 and PD1, and the layout matters — which bank an update lands in changed in an earlier PD release, so two banks sitting on different versions isn’t automatically a fault. There are also known cases where a PD bank reads 0.0 as a reporting artifact that clears on a later boot rather than a real erase. Yours didn’t clear across three attempts and two AC pulls, which is exactly why I’d rather see the full inventory than assume it either way.
Your fwupd line (expected 0x00000516, got 0x0000040a) does show the version didn’t move, so something failed. And the absence of any capsule result for the PD attempts, when EC and SoC from the same day logged normally, is the detail I’d most want firmware looking at.
On fieldiag — staying on 1.0.9-1 to keep ofed-scripts/doca-ofed off half a RoCE pair seems sensible, and nothing you’ve posted implicates the networking stack.
I don’t have a role in the consumer support ticketing system, thus I can’t take ownership of 261003-000005 or give you a timeline on it. I’m raising both the firmware question and the state of the case internally, and I’ll post back here if I get something concrete.
And to your first question, for the community: if anyone else has a PD bank reading 0.0 after this update, please say so here.
Hey Neill,
Thank you so much! I appreciate the straight answer and you raising it internally.
Here is the output from spark-3 (my affected node), taken today (unit has been up since Oct 3):
Associated Components: 0
Handle 0x004F, DMI type 45, 24 bytes
Firmware Inventory Information
	Firmware Component Name: PD Firmware
	Firmware Version: PD0 FW1: 0.0, FW2: 4.10
	Firmware ID: Not Specified
	Release Date: Not Specified
	Manufacturer: Not Specified
	Lowest Supported Firmware Version: Not Specified
Handle 0x0050, DMI type 45, 24 bytes
	Firmware Version: PD1 FW1: 5.22, FW2: 4.10
For comparison, my other three units (same board P4242 rev A04, same update) all read PD0 FW1: 5.22, FW2: 4.10 and PD1 FW1: 5.22, FW2: 4.10. So FW2 at 4.10 looks normal across the set, and the only difference on this unit is PD0 FW1.
On the reporting-artifact possibility: the 0.0 has been the same on every read since Oct 3, across two full AC removals and several reboots. The BIOS firmware page shows PD0 running from FW2 (4.10, Active) and PD1 from FW1 (5.22, Active).
On my units, I’ve seen reported BIOS versions that do not match the version actually running. I suspect those values reflect the original shipping firmware, although I haven’t confirmed that.
I’ve also experienced USB-C PD issues that cleared after unplugging the power adapter from the wall for a few seconds. I’m unsure whether that is related to your experience. I’ve spent considerable time investigating the PD firmware, but it is a fairly closed ecosystem, with limited options for inspection or modification.
One possible troubleshooting step is to ask fwupd to reinstall the existing PD firmware. I have not tested this method on my units, so I can’t confirm whether it would help:
sudo fwupdmgr refresh --force
fwupdmgr get-devices
fwupdmgr get-releases <PD_DEVICE_ID>
sudo fwupdmgr reinstall <PD_DEVICE_ID>
Replace <PD_DEVICE_ID> with the appropriate device ID from get-devices, and confirm that get-releases identifies the USB-C PD firmware before proceeding. This requires the currently installed version to remain available from the configured firmware source.
These commands request a same-version reinstall; they do not guarantee that the platform firmware will accept or perform the flash. Keep the power connected throughout the update, follow the reboot prompt, and check fwupdmgr get-historyafterwards.
The latest USB-C PD FW for the FE can be downloaded from https://fwupd.org/lvfs/devices/com.nvidia.dgx.spark.usbpd2.firmware and applied manually.
Inspect the CAB for Device ID, vendor, etc. It should match what’s on your Spark.
Here’s sample output of https://r2.fwupd.org/lvfs-prod/67b78ec42481411977b8f90eb1e8dc29ba5e536da87bce54113f736f9b17b9ca-usbpd.cab:
elsaco@spark2:~$ fwupdmgr get-details /tmp/usbpd.cab
Decompressing…           [   -                                   ]
NVIDIA NVIDIA_DGX_Spark
└─UEFI Device Firmware:
      Device ID:          a6c6b7f79c96a1cc84d9612d804675e0c3d879c4
      Summary:            UEFI System Resource Table device (Updated via capsule-on-disk)
      Current version:    0x00000516
      Minimum Version:    0x00000400
      Vendor:             NVIDIA (DMI:American Megatrends International, LLC.)
      Update State:       Success
      Update Error:       ->convert_version not implemented
      GUID:               dd1a238a-5f8e-46bd-9401-a88da99c5a96
      Device Flags:       • Internal device
                          • System requires external power source
                          • Supported on remote server
                          • Needs a reboot after installation
                          • Device is usable for the duration of the update
                          • Updatable
                          • Signed Payload
      Device Requests:    • Message
Apply with:
sudo fwupdmgr --verbose --verbose install /tmp/uspbd.cab
and save the output in case is needed for troubleshooting.
The CAB used for testing:
wget https://r2.fwupd.org/lvfs-prod/67b78ec42481411977b8f90eb1e8dc29ba5e536da87bce54113f736f9b17b9ca-usbpd.cab -O /tmp/usbpd.cab
It’s the latest available on LVFS
Hi Chris,
Thanks, I appreciate you sharing this.
On the BIOS version mismatch, I see the same thing: the SMBIOS type 0 string on three of my units is older than what dmidecode -t 45 reports, so I agree it looks like a stale value rather than a real difference.
On the power adapter: I did two full AC removals (60 and 70 seconds), and PD0 FW1 still reads 0.0.
On reinstall: fwupd reports my PD device at 0x0000040a, and get-releases only offers 0x500, 0x507 and 0x516, all as upgrades. So there is no same-version release for it to reinstall. Separately, NVIDIA support has asked me to hold off on any further PD update attempts while the case is open, so I’m leaving it untouched for now.
Hi Elsaco,
Thanks for taking the time to write this up, I appreciate it.
I checked, and that is the same CAB my unit already tried. The fwupd history on the affected Spark shows the PD release with SHA-256 67b78ec42481411977b8f90eb1e8dc29ba5e536da87bce54113f736f9b17b9ca, matching the file in your link, same device ID and GUID. It was staged by fwupdmgr update rather than a manual install, but it is the same capsule, and it has failed three times with “expected 0x00000516 and got 0x0000040a”.
NVIDIA support has asked me not to make any further PD update attempts while the case is under review, and since PD0 is currently running from its only valid bank, I’d rather not risk another write without their say-so.
If the firmware team wants a retry with --verbose --verbose to capture the log, I’m glad to do that on their instruction.
Thanks @robert318 — and thanks @christopher_owen and @elsaco for pitching in.
Your dmidecode settles the question I had. One bank at 0.0, unchanged across two AC removals and several reboots, with three same-revision units reading 5.22 in that slot, rules out the transient reporting behaviour I wanted to exclude. The BIOS page and dmidecode agreeing on which image is Active points the same way.
You’ve also answered both suggestions yourself, so I’ve nothing to add: with get-releases offering only 0x500, 0x507 and 0x516 as upgrades there’s no same-version release to reinstall, and the CAB @elsaco linked is the one your unit already staged. Holding where you are is right, and I’d keep holding.
I’ll relay your offer of a --verbose --verbose retry — that’s a useful thing to have on record.
One thing I should have asked earlier, whenever you’re back and able — on the affected unit and on one that updated cleanly:
mokutil --sb-state
The missing capsule results are the part I can’t account for, and Secure Boot state sits on that path. difference there would be worth chasing; all four matching rules it out just as usefully.
This is logged internally now with your dmidecode attached.
For anyone else reading with a PD bank at 0.0 — please post here rather than manually flashing. There’s no same-version reinstall available, and a retry on a single-banked controller isn’t a free action.
Thanks Neill, that’s very helpful, and thank you for logging it.
Here is mokutil --sb-state from all four units:
spark-1 (updated cleanly):  SecureBoot enabled
spark-2 (updated cleanly):  SecureBoot enabled
spark-3 (affected):         SecureBoot disabled
spark-4 (updated cleanly):  SecureBoot enabled
So there is a difference: the affected unit is the only one with Secure Boot off. It arrived that way. I have never changed the Secure Boot setting on any of the four. The keys are enrolled on the affected unit, it is just switched off.
For context, this unit was purchased from the NVIDIA Marketplace on September 10 and the first PD attempt was on September 16, alongside the EC and SoC capsules, which applied successfully.
I haven’t changed the setting and won’t unless the firmware team wants it changed. Happy to run anything else read-only.
@robert318 you could get the results from the last update. It’s read-only. For that specific DEVICE-ID run fwupdmgr get-results a6c6b7f79c96a1cc84d9612d804675e0c3d879c4. Add -v or --verbosity flag and there will be a detailed output of what happened during the last update.
Hi @robert318 — thanks, that’s the most useful result so far. The affected unit being the only one of the four with Secure Boot disabled is a real difference, and it sits right on the part I couldn’t account for: no capsule result for any PD attempt. I’ve added it to the internal report alongside your dmidecode output.
Please leave Secure Boot as it is for now, so firmware can look at the unit in the state the failure happened in.
@elsaco’s suggestion is a good one and it’s read-only, so if you can, please post the output of:
fwupdmgr get-results a6c6b7f79c96a1cc84d9612d804675e0c3d879c4 -v
That should show what fwupd recorded for the last PD attempt, which is the gap we’re trying to fill.
Nothing else changes: keep holding the unit as it is, with no further PD update attempts. Firmware is looking at this, and I’ll post here as soon as there’s a concrete answer on recovery or replacement.
Hi Neill, thanks for all your help. An update, and I’m sorry it crosses with your request to leave the unit as it was.
Before I saw your post, the Secure Boot disparity with the other Sparks was really bugging me. So, I enabled Secure Boot (Standard mode) in the BIOS, changed nothing else, re-ran the same update and rebooted normally. It applied on the first try. So the unit is no longer in the failed state.
Before: PD0 FW1 0.0 / FW2 4.10, PD1 FW1 5.22 / FW2 4.10, ESRT fw_version 0x40a
After: PD0 FW1 5.22 / FW2 4.10, PD1 FW1 5.22 / FW2 5.22, ESRT fw_version 0x516, last_attempt_status 0
Differences from the failed attempts: the firmware showed an update progress screen, the boot took about 2 minutes instead of 35 seconds, a capsule result variable was written for the PD GUID (status 0), and the capsule file was removed from EFI/UpdateCapsule.
I captured the failed state read-only before changing anything, so this should still be useful to firmware:
- The staged capsule was byte-identical to usbpd.cap in the LVFS package (sha256 0072e4c15b6dd897dad8d137e0e0a866dd42eb9f614f5a9bbe77457cfb007ee6).
- No capsule result variable existed for any PD attempt, while my three healthy units each have EC, SoC and PD entries from their update boot.
- ESRT showed last_attempt_version 0x516 with last_attempt_status 0 while fw_version stayed 0x40a.
- OsIndications was 0 after the attempt, but the capsule file was still on the ESP.
- Firmware time on the attempt boot was only about 2.5 s longer than a normal cold boot.
- CapsuleLast was Capsule0004 although Capsule0005 and Capsule0006 existed.
- Only this unit has factory-era result variables (2025-10-03), including the PD capsule applied twice.
- The EC and SoC capsules applied normally on this unit with Secure Boot disabled. Only PD was affected.
fwupdmgr get-results for the device now reflects the successful run (Update State: Success, previous version 0x0000040a, 2026-10-08 23:03:44 UTC). From the failed state I have the get-history entry: “failed to run update on reboot: expected 0x00000516 and got 0x0000040a”.
Since then the unit has passed a load test at about 190 W wall draw and a cold start, with the PD banks unchanged.
Two things I’d flag for firmware:
1. With Secure Boot disabled the PD capsule reported success (ESRT status 0) without being applied. A failure status would have pointed at this much sooner.
2. Field Diagnostics requires Secure Boot disabled. Anyone who runs it and then updates firmware without re-enabling Secure Boot could end up in the same state.
This is one unit, so I can’t say whether every Spark behaves this way with Secure Boot off or only ones with this unit’s factory history. I have a full write-up with the commands and outputs and can post it here or attach it to the support case, whichever is more useful to you. Let me know your thoughts. The Rep on the case has opened an RMA for me though that I can follow. Do you have any thoughts on whether this should hold or should I still RMA the device?
Hi @robert318 — thanks for the thorough update, and no apology needed; you’d already enabled Secure Boot before my request crossed yours. That turn of events actually answers the core question.
The evidence is strong: with Secure Boot disabled the PD capsule reported success (ESRT 0) without applying, and with it enabled the same capsule applied cleanly on the first try. That pattern, plus the extra boot time and capsule result variable when it worked, points to Secure Boot being the difference. I’ve added all of your captured data to the internal report — the staged capsule hash, the missing capsule result, the ESRT behaviour, and the factory-era variables are exactly the kind of detail firmware will want.
On the RMA: now that the unit is running the current PD firmware (0x516) on both controllers and passes load/cold-start tests, the failure condition you originally reported no longer exists. Whether to still proceed with the RMA is your call, but it would be reasonable to share this outcome with the support rep and ask whether the case can be reassessed. I can’t decide that for you, and I don’t have a timeline, but I’ve noted the resolution.
On Secure Boot: keep it enabled for normal operation. If you need to run Field Diagnostics (which requires it disabled), re-enable Secure Boot before any future firmware update — that’s the key step to avoid repeating this. I’ve flagged that internally.
For the write-up: you have a full write-up with commands and outputs. It would be most useful attached to the support case as well, so it’s on record there; if you post it here, I’ll make sure it gets folded in. Either way, the internal report already has the captured data.
If firmware wants any additional logs from the failed state, I’ll post here. Otherwise, the case is now in a much better place. Thank you for the careful write-up.
Neill, you’ve been great. I really appreciate your prompt replies, your thoroughness, and your help. This is an awesome community and yet another reason why I love being a hobbyist. I sent you a more detailed dump directly to you via DM.
