NVIDIA Sync fails to authenticate with “attempted methods [none]” — persists after clean reinstall, custom SSH config, and even matching the nvsync.key filename convention
I’m unable to connect NVIDIA Sync to my DGX Spark. Every connection attempt fails with:
ssh: handshake failed: ssh: unable to authenticate, attempted methods [none], no supported methods remain
From the Sync logs:
{"level":"info","message":"Added host to known_hosts"}
{"level":"error","error":"ssh: handshake failed: ssh: unable to authenticate, attempted methods [none], no supported methods remain","message":"Could not create new SSH connection to <spark-ip>:22"}
Note that only [none] is listed as an attempted method — Sync never even attempts password or publickey, despite the Add Device form asking for a password. The host key exchange itself succeeds fine (host gets added to known_hosts), so this is purely an authentication-offering issue on Sync’s side.
Troubleshooting already performed (no change in behavior across any of these)
- Confirmed the target host is reachable and the SSH handshake itself succeeds (host key is added to
known_hostsevery time) - Confirmed native OpenSSH from the same Windows machine connects successfully using a dedicated key pair (
ssh -i <key> user@hostworks with zero prompts, no password needed) - Generated a fresh SSH key pair specifically for this test, installed the public key in
authorized_keyson the Spark - Manually created
%LOCALAPPDATA%\NVIDIA Corporation\Sync\config\ssh_configwith an explicitHostentry pointingIdentityFileto the working key - Confirmed
%USERPROFILE%\.ssh\configcorrectly contains theIncludeline pointing to the above file (this was present after reinstall, so Sync itself creates it) - Fully uninstalled Sync, deleted all residual config/AppData/Program Files/registry entries, reinstalled the latest version from scratch — identical error persists
- The “Add Device” dialog never shows any imported SSH alias list, even though documentation states one should appear when a valid
ssh_configentry exists - Per a suggestion from thread 376096 (reply #3), tried naming the identity file
nvsync.keyand placing it directly in Sync’s own config folder (%LOCALAPPDATA%\NVIDIA Corporation\Sync\config\nvsync.key), with the path quoted to handle the space in “NVIDIA Corporation”. Still identical[none]result.
Since the log shows [none] as the only attempted method in every single scenario above — including ones where a confirmed-working key was explicitly configured — it strongly suggests the “Add Device” connection flow does not actually consult ssh_config at all when establishing the connection, contrary to what the documentation implies. It appears to unconditionally attempt an unauthenticated connection and fail, regardless of any local key configuration.
Environment
- OS: Windows
- NVIDIA Sync: Version: 0.117.3-12
- Device: DGX Spark
- SSH working correctly both via WSL and native Windows OpenSSH to the same host with the same credentials
Has anyone found an actual working fix, or can NVIDIA staff confirm whether this is a known bug in the Add Device / connection flow?
