Hi all,
I am having problems launching the Nvidia System Profiler in my host. I got the Standalone binary from here: Gameworks Download Center | NVIDIA Developer
My host is an Ubuntu 18.04 (through docker) and my target is going to be a Drive PX2 board (AutoChauffeur).
The profiler is using the following configuration
$ cat nvlog.config
# Rename this file to nvlog.config and put into one of the two places:
# * Next to the SystemProfiler binary.
# * Into your current directory.
# Enable all loggers:
+ 50iw 50ef 0IW 0EF global
# Append logs to a file:
$ SystemProfiler.log
# Flush the log file after every log message:
ForceFlush
# On Windows, use OutputDebugString():
OutputDebugString
# Log into stdout:
UseStdout
# Specify logging format:
# Simple format
# Format $time $tid $name $text
# A more verbose variant of logging format:
Format $sevc$time|${name:0}|${tid:5}|${file:0}:${line:0}[${sfunc:0}]: $text
The profiler is not launching and I only get the following log
$ ./SystemProfiler
I12:49:27:397|CrashReporter| 1245|:86[]: Server 7 client 6 for process
I12:49:27:442|HostApp| 1249|Main.cpp:71[setupDpiScaling]: The interface scaling factor set to 1;1.
I12:49:27:459|AppLib_Script| 1249|Manifest.js:3[<global>]: Loading CorePlugin
F12:49:27:462|HostApp| 1249|Main.cpp:169[main]: Merged manifest has no application name
F12:49:27:462|HostApp| 1249|Main.cpp:170[main]: Merged manifest has no application version
E12:49:27:462|HostApp| 1249|Main.cpp:171[main]: Merged manifest has no application id
E12:49:27:462|HostApp| 1249|Main.cpp:172[main]: Merged manifest has no application docs
libGL error: MESA-LOADER: failed to retrieve device information
libGL error: Version 4 or later of flush extension not found
libGL error: failed to load driver: i915
libGL error: failed to open drm device: No such file or directory
libGL error: failed to load driver: i965
E12:49:27:517|AppLib| 1249|:264[]: Layout default was not found
E12:49:27:517|AppLib| 1249|:297[]: Error restoring layout: default
Apparently, the profiler is hanging.
Any hint on how to fix this?
