Nvidia_tao_core.microservices.app - ERROR - Exception on /api/v2/tao_api_notebooks.zip [GET]
• Hardware (T4/V100/Xavier/Nano/etc) - T4
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) - NA
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here) - NA
• Training spec file(If have, please share here) - NA
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.) - <host_url>//api/v2/tao_api_notebooks.zip in browser
2026-01-07 09:08:02,550 - nvidia_tao_core.microservices.app - ERROR - Exception on /api/v2/tao_api_notebooks.zip [GET]
File “/opt/venv/cosmos_rl/lib/python3.12/site-packages/flask/app.py”, line 1511, in wsgi_app
response = self.full_dispatch_request()
File “/opt/venv/cosmos_rl/lib/python3.12/site-packages/flask/app.py”, line 919, in full_dispatch_request
File “/opt/venv/cosmos_rl/lib/python3.12/site-packages/flask/app.py”, line 917, in full_dispatch_request
rv = self.dispatch_request()
File “/opt/venv/cosmos_rl/lib/python3.12/site-packages/flask/app.py”, line 902, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args) # type: ignore[no-any-return]
File “/opt/venv/cosmos_rl/lib/python3.12/site-packages/nvidia_tao_core/microservices/decorators.py”, line 40, in decorated_function
return f(*args, **kwargs)
File “/opt/venv/cosmos_rl/lib/python3.12/site-packages/nvidia_tao_core/microservices/blueprints/v2/admin.py”, line 130, in download_folder
shutil.make_archive(“/tmp/tao_api_notebooks”, ‘zip’, “/shared/notebooks/”)
File “/usr/lib/python3.12/shutil.py”, line 1144, in make_archive
stmd = os.stat(root_dir).st_mode
FileNotFoundError: [Errno 2] No such file or directory: ‘/shared/notebooks/’
127.0.0.1 - - [07/Jan/2026:09:08:02 +0000] “GET /api/v2/tao_api_notebooks.zip HTTP/1.1” 500 334 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/143.0.0.0 Safari/537.36 Edg/143.0.0.0”
Please help resolve this as the notebooks can’t be downloaded at <host_url>/tao_api_notebooks.zip
Thanks & regards,
Projjwal
Could you please run from a shell inside the TAO microservice container/pod:
mkdir -p /shared/notebooks
chmod 755 /shared/notebooks
Then retry:
<host_url>/api/v2/tao_api_notebooks.zip
or
I executed the command against tao-api-app-pod-56b454f945-l7r89
I executed the command against tao-api-app-pod-56b454f945-l7r89 pod and it worked fine as I checked the dir and its permission
later I tried both below
it returned
‘404 not found’
it returned
“code”: 404,
“name”: “Not Found”,
“description”: “The requested URL was not found on the server. If you entered the URL manually please check your spelling and try again.”
attached here’s the log from tao-api-app-pod-56b454f945-l7r89 pod and also below is code from the templates\ingress-notebooks.yaml used for deployment
# Copyright (c) 2024, NVIDIA CORPORATION. All rights reserved.
# Licensed under the Apache License, Version 2.0 (the “License”);
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an “AS IS” BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
{{- if .Values.ingressEnabled }}
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
name: {{ .Release.Name }}-ingress-notebooks
namespace: {{ .Release.Namespace }}
annotations:
nginx.ingress.kubernetes.io/proxy-buffer-size: 128k
nginx.ingress.kubernetes.io/proxy-http-version: "1.1"
nginx.ingress.kubernetes.io/connection-proxy-header: ""
{{- if .Values.tlsSecret }}
nginx.ingress.kubernetes.io/ssl-redirect: "true"
nginx.ingress.kubernetes.io/force-ssl-redirect: "true"
nginx.ingress.kubernetes.io/server-snippet: |
  error_page 497 https://$server_name:$server_port$request_uri;
{{- end }}
nginx.ingress.kubernetes.io/use-regex: "true"
nginx.ingress.kubernetes.io/rewrite-target: /$1/tao_api_notebooks.zip
{{- if .Values.corsOrigin }}
nginx.ingress.kubernetes.io/enable-cors: "true"
nginx.ingress.kubernetes.io/cors-allow-origin: {{ .Values.corsOrigin }}
{{- end }}
nginx.ingress.kubernetes.io/configuration-snippet: |
  more_set_headers "X-Frame-Options: SAMEORIGIN";
  more_set_headers "X-XSS-Protection: 1; mode=block";
  more_set_headers "Strict-Transport-Security: max-age=31536000; includeSubDomains; preload";
{{- end }}
spec:
ingressClassName: nginx
tls:
  • secretName: {{ .Values.tlsSecret }}
{{- if .Values.host }}
hosts:
- {{ .Values.host }}
{{- end }}
{{- end }}
rules:
  • http:
    paths:
    • path: /{{ .Release.Namespace }}/tao_api_notebooks.zip
      pathType: ImplementationSpecific
      backend:
      service:
      name: {{ .Release.Name }}-service
      port:
        number: 8000
{{- if eq .Release.Namespace “default” }}
  - path: /tao_api_notebooks.zip
    backend:
      service:
        port:
          number: 8000
{{- end }}
{{- if and .Values.host }}
host: {{ .Values.host }}
{{- end }}
{{- end }}
Please suggest further step to help resolve the issue
Thanks & regards,
Projjwal
notebook_zip_error_log.txt (1.7 MB)
The notebooks for tao-api are all inside tao_tutorials/notebooks/tao_api_starter_kit at main · NVIDIA/tao_tutorials · GitHub. May I know which .ipynb file you are running? Thanks.
Please try below to narrow down.
  1. Run curl inside the Pod. To check if it can return 200.
kubectl exec -it tao-api-app-pod-56b454f945-l7r89 -- bash
curl -v http://127.0.0.1:9000/api/v2/tao_api_notebooks.zip -o /tmp/test_notebooks.zip
The official TAO 5.5 ingress-notebooks.yamltao-core/chart/templates/ingress-notebooks.yaml at tao_5.5_release · NVIDIA/tao-core · GitHub )uses nginx.ingress.kubernetes.io/rewrite-target: /tao_api_notebooks.zip and does not contain $1 in the rewrite-target.
If your current Ingress uses /$1/tao_api_notebooks.zip while the path does not define any capture group (…) , then $1 will always be empty and the rewrite rule will not behave as intended.
To align with the official chart and avoid rewrite issues, please change your Ingress annotation to: nginx.ingress.kubernetes.io/rewrite-target: /tao_api_notebooks.zip and redeploy, then retry <host_url>/tao_api_notebooks.zip.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
