NVIDIA technical-confirmation request
Please confirm for two identical Jetson AGX Orin developer kits using P3737-A05 carriers, configured as C5 root port and C5 endpoint with a 300 mm Gen4 ×8 interconnect:
  1. The permitted UPHY_REFCLK0 voltage and injection-current bounds when the endpoint module is unpowered, partially powered, brownout, or shutting down, and required isolation timing relative to CARRIER_POWER_ON and module supplies.
  2. Whether a fixed external-reference-clock receive path replacing the carrier clock mux is permitted; provide applicable pad mapping, receiver termination and clock electrical/timing specifications.
  3. Exact PEX_L5_RST_N pad type/voltage domain, VIL/VIH over rail tolerance, guaranteed internal pull-up resistance bounds and any pad alias to PEX_C5_RST_N.
  4. The validated C5 endpoint reset and common-clock configuration for JetPack 7.2.1 / L4T r39.2.1.
  5. If common-clock replacement is not supported, whether C5-to-C5 SRNS is supported in that release, with exact firmware/DT configuration and any EP_READY_N/sideband requirements.
Thank you for your questions regarding the AGX Orin C5 RP-to-EP configuration.
Clocking Recommendation (Q1, Q2, Q5)
Per Jetson AGX Orin Series Design Guide (DG-10653-001 v1.8) Figure 7-5 and its associated Notes, SRNS (Separate Reference clocking with No Spread) is strongly recommended for the C5 RP ↔ C5 EP connection. In this mode, each SoC supplies its own reference clock internally using its PLLE. The clock output from the Root Port is only recommended as a backup option. Please note that SRNS disables Spread Spectrum Clocking (SSC), so the EMI impact with SSC disabled must be considered.
PEX_C5_RST_N Pin Specification (Q3)
This is documented in Table 7-15 of the same Design Guide. PEX_C5_RST_N is an Open-Drain, 3.3V type pad with a 4.7KΩ pull-up to 3.3V on the module.
