Hi all,
We’re using the ISL79987 with Jetson AGX Orin, the ISL79987 chip has a 480i output, we’re having some questions related to nvidia tegra drivers :
- Why in channel.c the size of allocated buffer is dubbed when the used mode is interlaced ?
/* Double the size of allocated buffer for interlaced sensor modes */
if (chan->is_interlaced)
chan->format.sizeimage *= 2;
Is there anything to update in nvidia tegra drivers if we’re using an interlaced scan sensor despite of progressive ?
In case the sensor has interlaced scan do we have to set the is_interlaced boolean at true as the following ?
chan->is_interlaced = 1;
chan->interlace_type = Top_Bottom;
