NVIDIA Tegra samplerExternalOES Shader Linker Bug
Gpu: Nvidia shield (Android)
NVIDIA software Version: 9.2.2 (33.2.0.382)
Bug: glLinkProgram incorrectly fails when both vertex and fragment shaders declare the same uniform samplerExternalOES, even when the vertex shader does not use it.
To properly explain this issue, I open a repository with the code to reproduce the issue AND I explained the issue in the README: GitHub - moi15moi/nvidia-tegra-repro-opengl · GitHub
Is there any additionnal information I can give you to help you?
I’m closing this because I realised I didn’t post the question in the right topic.
I reopened it here: NVIDIA Tegra samplerExternalOES Shader Linker Bug
