Hi, I installed a NVIDIA Tesla V100 SXM3 32 GB card on an hpe dl380 g10 server. It recognizes PCI\VEN_10DE&DEV_1DB8&SUBSYS_12AB10DE&REV_A1 in the hardware ids virtual machine, for which there is no driver. What should I do to solve the driver problem?
Hi there @meisam.abd, welcome to the NVIDAI developer forums.
I am not certain what exactly the problem is. If you go to Download The Latest Official NVIDIA Drivers and check for Data Center and V100 for the operating system you plan to install, there will be a driver for you to use.
If you want to virtualize the GPU usage, you will need to check Virtual GPU (vGPU) | NVIDIA and go through Enterprise support.
