I’m having problem with newest version, when I export files as .dds, some files has not enough mipmap and that is problem for me (btw I already did max mipmap in interface but still not have enough mipmap). Old versions like 2022-2023 was working normally. Is anyone has this version?
Hi @KataZuki! There’s a bug in the latest version of the Exporter that makes it generate too few mipmaps when the width of the image is less than the height. I’ve got more details on this at Need non-square image to generate all mips down to 1x1 - #3 by nbickford, and will update both threads once the fixed version is released.
Okay, thank you for reply! Can I get old version of Photoshop plugin please? Because I have work to do.
Yep! Here’s a direct link to the previous version, which should work if you’re logged in: Log in | NVIDIA Developer
Hi @KataZuki! I’m happy to say that we’ve released NVIDIA Texture Tools 2024.1.1 today, which fixes the issue where it would generate too few mipmaps for portrait-mode images. Here’s the release notes.
If you could try it out and let me know if it works for you, it’d be much appreciated – thanks again!
Hi @nbickford! I have tried new version today. It is working perfect and there is any minmap problem. Thank you so much and have a good day!
