Nvidia Texture Tool Exporter error: "Creating the window with GLFW failed!"
I have the newest version of photoshop and Nvidia texture tool exporter plugin (both installed yesterday).
When I try to save a photoshop file as a dds I get an error:
“Error: Creating the window with GLFW failed!
Internal info: nvttui::ExporterPlugin::InitializePlugin, line 1389.”
Any advice?
Hi inbarkoren.im! Do you happen to know what driver version you’re using (which can be found using dxdiag)?
Usually when we’ve seen this, it’s because the app uses OpenGL 4.6, and the driver might not be up to date (all recently released drivers I know of have support, but some older integrated GPU drivers don’t). Here’s a similar issue.
Hey !
I have a completely similar problem!
Uploaded a new version of the tool for working with DDS,
I show the PC configuration on the screenshots:
work station:
Operating System: Windows 10 64-bit
Vendor name: INTEL
Description: Intel (R) UHD Graphics 630
Graphics editor:
Adobe Photoshop Version: 22.3.0 20210302.r.49 660cd2e x64
NVIDIA_Texture_Tools_Exporter_for_Adobe_Photoshop_2021.1.1
When trying to save DDS, an error pops up:
"Error: Creating the window with GLFW failed!
Internal info: nvttui :: ExporterPlugin :: InitializePlugin, line 1389. "
Graphics driver version:
Device name: Intel (R) UHD Graphics 630
Vendor name: INTEL
OpenGL version: 4.6 (4.6.0 - Build 27.20.100.9466)
GLSL version: 4.60 (4.60 - Build 27.20.100.9466)
I am waiting for help, as the work was completely stopped due to the presence of such a fatal error …
I will repeat my question, since I did not wait for an answer from the plugin developers.
Today I updated the graphics driver to the latest version 30.0.100.9684
but the error did not disappear, when trying to save DDS, it gives the same error code
buenos días tengo un problema porque Cuando trato de guardar un archivo de Photoshop como dds, aparece un:
error: ¡falló la creación de la ventana con glfw! información interna: nvttui::exporterplugin::initializeplugin, línea 1494
