An abnormal data reception issue has been observed while bringing up the camera on the Thor platform. We would appreciate your assistance in troubleshooting the root cause.
The deserializer is configured at 1.5 Gbps/lane.
The dmesg information is as follows:
The device tree configuration is as follows:
The trace information is as follows:
trace.txt (106.9 KB)
Thanks for visiting the NVIDIA Developer Forums.
To ensure better visibility and support, I’ve moved your post to the DRIVE category where it’s more appropriate
Cheers,
Tom
Dear @Stephen078 ,
Could you confirm if the used platform is DRIVE AGX Thor devkit? If so, what is the DRIVE OS version and camera module details?
Thank you for your inquiry. We are not using the standard NVIDIA DRIVE AGX Thor DevKit. Instead, we have developed our own custom carrier board based on the Thor SoC.
Regarding your questions:
AGX Thor OS Version: We are currently using kernel 6.8
Camera Module Details: Our camera system uses Maxim (ADI) GMSL SerDes chips. The serializer is MAX96717F, and the deserializer on our Thor board is MAX96716. The sensor outputs UYVY 16bit format video at a resolution of 1920x1536.
Moving to Jetson Thor forum
What image sensor does your camera module use?
Can you post your json file
uses the Sensing ISX031 image sensor,this is device-tree file
tegra264-p4071-camera-sensing-SG3S11AFSK-overlay-007.dts.2lanes.txt (5.7 KB)
You could try changing csi-mode = "2x4" to "1x2" in MAX96716 deserializer and gmsl-link nodes; or “2x2” if you are using both MAX96716 output ports. Your overlay declares csi-mode = “2x4” on the MAX96716 deserializer node while everything else — bus-width, num-lanes, num_csi_lanes, num_lanes is 2.
For clarification, what is results of:
cat /etc/nv_boot_control.conf
cat /etc/nv_tegra_release
uname -a
soc:jeston agx thor t4000 38.2 jpack 6.8 kernel
The log shows NVCSI per-VC packet errors, not a VI scheduling issue.
STREAM_VC ... vc:0 status:0x00000004 means bit 2 set = pd_crc_err, i.e. packet payload CRC check failed on VC0.
STREAM_VC ... vc:6 status:0x00000022 = 0x20 + 0x02, so:
- bit 5 =
embedded_line_crc_err
- bit 1 =
ph_ecc_single_bit_err, i.e. single-bit ECC error in the packet header.
CHANSEL_SHORT_FRAME ... data:0x0000200001000000 is the same short-frame signature we decoded earlier: pixel short frame with pixel-incomplete indication.
CSIMUX_FRAME ... data:0x...00a0 means FE plus FS_FAULT, so VI/CSIMUX saw a frame end but the frame start/sequence was abnormal.
So the practical read is:
VC0 has payload corruption, and VC6 has embedded-data/header corruption, followed by a short/abnormal frame on the VI side.
About the rtcpu_unknown id:0x000d0007/000d0009 lines: I don’t have a clean internal decode for those IDs from the references I pulled, so I would treat them as auxiliary raw FW records around the same error window, not the primary signal.
Most likely things to check next:
- CSI link quality / corruption source
- embedded-data packet config.
Okay, let’s check it out.
