I’m building an industrial AI vision system using 16 × 5GigE machine vision cameras on a rubber glove production line. All 16 cameras trigger simultaneously, producing an aggregate burst of ~13–27 Gbps (depending on ROI) within a 43 ms window.
We’re exploring a custom carrier board for the Jetson T5000 with 8 × 10GbE RJ45 ports either by fanning out the native 4×25GbE (QSFP28) lanes via an on-board PHY/switch chip, or by adding a multi-port 10GbE NIC over PCIe.
- Has anyone done a T5000 carrier with more than 2 × 10GbE? Any recommended silicon for the QSFP28 fan-out?
- Is PCIe Gen5 x8 on the C4 controller verified for a multi-port 10GbE NIC at full line rate?
- Can PoE++ (802.3bt) PSE circuits (e.g. TI TPS23861) be integrated on a Jetson carrier board without power sequencing issues? Total PoE load would be ~112W across 16 cameras.
