Nvidia,tx-clk-tap-delay and nvidia,rx-clk-tap-delay More details required
Hello All,
Need more details on this:
  • nvidia,tx-clk-tap-delay: Delays the clock going out to the external device
    with this tap value.
  • nvidia,rx-clk-tap-delay : Delays the clock coming in from the external
    device with this tap value.
-Thanks.
Hello All,
After cs low, controller gives the above parameter value clock delays.
Is this correct? Please confirm.
-Thanks.
hello balajinp21,
they’re spi-client device controller properties. you should also refer to kernel documentation for more details.
for example,
$L4T_Sources/r32.5.1/Linux_for_Tegra/source/public/kernel/kernel-4.9/Documentation/devicetree/bindings/spi/nvidia,tegra114-spi.txt
