Hi, reading the SOM spec it indicates the maximum voltage is 19V. Is this the absolute maximum? We would like to run the SOM from USB C which supports up to 20V.
The VDD_IN supply to 3V/5V regulator TPS54335DRCT and high side MOS of VDD_CPU/GPU on TX1 module.
The input for TPS54335DRCT is 4.5v to 28v, Max voltage on MOS is 30v.
So the absolute maximum VDD_IN should be 28v for TX1 mudule
In JTX1 OEM Product DesignGuide, The VDD_IN is 5.5v to 19.6v with ±5% tolerance.
So,I think 20V should be safe.
