Hello All,
I’ve been hunting this down for a while now. I have a question about FSAA under ubuntu on the TX2.
Classically, I’ve changed these settings using the nvidia-settings app on x86 based systems.
as described here: https://download.nvidia.com/XFree86/Linux-x86_64/340.17/README/openglenvvariables.html
Any tips on how to change these settings on the TX2?
-B
BUMP
I’m still looking for a solution here. I can only enable 4 samples per pixel, I’d like to be able to enable 16 samples per pixel.
On x86, I’ve confirmed that I can change the antialiasing settings using nvidia-settings, but as it’s not available on the TX1/TX2, I’m stuck.
I’ve tried setting environment variables too, but to no affect.
Is there any way to enable the FSAA / set samples per pixel via other means?
I’d need them to be sticky if possible
Yeah, I’d like to know too…
I’ve put an FXAA shader on the TX2, and it seems to be ignored, the same shader works fine on the desktop GPU. So I’m now wondering how any AA works on the tx2…
