My computer has an nvidia 520M, Ubuntu 14.04 64 bits with kernel 3.13 installed, CUDA toolkit 6.5rc and nvidia-340.24 driver from xorg edgers. Installation and samples compilation went perfectly, but I can’t run any simple because it says
modprobe: FATAL: Module nvidia-uvm not found.
I have read other topics like “334.21 driver returns 999” and tried the exposed solutions and now I can’t even acces my Desktop.
When I run
dkms install -m nvidia-340-uvm/340.24
It says that kernel 3.12 is already patched or something like that. So the only think that I can figure out is that my kernel is 3.13 and cuda is trying to path 3.12 kernel.
Is there a reason why you need CUDA 6.5 ? I know ubuntu 14.04 handles CUDA 5.5 just fine.
On my card GeForce GT 645M as of yesterday I had issues when trying to install 6.5
The corresponding Nvidia driver 331 matches up with CUDA 5.5
dpkg --list | grep nvidia | grep ^ii | cut -c1-88
ii nvidia-331 331.89-0ubuntu1~xedgers14.04.2
ii nvidia-331-dev 331.89-0ubuntu1~xedgers14.04.2
ii nvidia-331-uvm 331.89-0ubuntu1~xedgers14.04.2
ii nvidia-common 1:0.2.91.5
ii nvidia-libopencl1-331 331.89-0ubuntu1~xedgers14.04.2
ii nvidia-opencl-icd-331 331.89-0ubuntu1~xedgers14.04.2
ii nvidia-prime 0.6.2
ii nvidia-settings 340.24-0ubuntu1~xedgers14.04.1
A quick way to confirm your CUDA is OK issue the make command
in below dir then as sudo issue :
