A lot of sample projects fail to load in VS2019 and target old SDKs (10.0)
i.E AppDecD3D
Where do i find samples for h264 decoding with support for VS2019?
i.E AppDecD3D
Hi.
We do not see any issue while loading sample projects in VS2017. Can you confirm that is the same behavior you see as well? If you still see problem in VS2017, can you provide an exact error information?
For failure in loading sample projects in VS2019, bug 200586753 is now filed internally.
thanks for your support.
I tried the samples with VS2019 not with VS2017
i cannot confirm the issue with VS2017, but
says for System Requirements:
Development Environment
Windows: Visual Studio 2010/2013/2015
Linux: gcc 4.8 or higher
I am missing VS2017 and VS2019 here …
I tried the samples with vs2013,failed.
c:\video_codec_sdk_9.1.23\samples\nvcodec\nvencoder\nvencoder.h(428)
fatal error C1001,compiler inner error
and when i with vs2019,failed also,showing:
C:\Video_Codec_SDK_9.1.23–old1\Samples\AppEncode\AppEncCuda>“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\bin\nvcc.exe” -gencode=arch=compute_30,code="sm_30,compute_30" --use-local-env -Xcompiler /wd4819 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2019\Enterprise\VC\Tools\MSVC\14.25.28610\bin\HostX86\x86” -x cu -I…..\NvCodec -I…....\include -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2\include" -G --keep-dir C:\Video_Codec_SDK_9.1.23–old1\Samples\Win32.Debug\AppEncCuda -maxrregcount=0 --machine 32 --compile -cudart static -g -DWIN32 -D_DEBUG -D_CONSOLE -D_LIB -D_CRT_SECURE_NO_WARNINGS -D_UNICODE -DUNICODE -Xcompiler "/EHsc /W3 /nologo /Od /FdC:\Video_Codec_SDK_9.1.23–old1\Samples\Win32.Debug\AppEncCuda\vc142.pdb /FS /Zi /RTC1 /MDd " -o C:\Video_Codec_SDK_9.1.23–old1\Samples\Win32.Debug\AppEncCuda\crc.cu.obj “C:\Video_Codec_SDK_9.1.23–old1\Samples\Utils\crc.cu”
1>nvcc fatal : 32 bit compilation is only supported for Microsoft Visual Studio 2013 and earlier
