VK_ERROR_INVALID_DRM_FORMAT_MODIFIER_PLANE_LAYOUT_EXT, NVIDIA 595.71.05.
Symptom
Same NV12 dma-buf, allocated by NVIDIA’s own GBM, fed into Vulkan via
two different create-info chains:
Format │ GBM alloc │ EGL import │ VK (explicit) │ VK (list)
NV12 │ ok (mod=0x300000000606014) │ ok │ FAIL │ ok
(vkCreateImage rejects)
VkImageDrmFormatModifierExplicitCreateInfoEXT(caller passes
modifier + per-plane offsets/pitches): rejected. This is the
path ANGLE’sDmaBufImageSiblingVkLinux.cppuses.VkImageDrmFormatModifierListCreateInfoEXT(caller passes a
list of candidate modifiers, driver picks the layout itself):
accepted. This is the path libplacebo / mpv / Wayland
compositors use.
So the buffer itself is valid; only the explicit-layout entrypoint’s
validation rejects it.
User-visible: Chromium with --use-angle=vulkan on NVIDIA X11 falls
back to software video decode, surfacing as
DmaBufImageSiblingVkLinux.cpp:initImpl:616 VK_ERROR_FEATURE_NOT_PRESENT
in chrome logs. Underlying vkCreateImage returns
INVALID_DRM_FORMAT_MODIFIER_PLANE_LAYOUT_EXT. There is no
workaround: the latest stable Chromium dropped the GLX backend, and
the default ANGLE-on-EGL path also fails because NVIDIA’s EGL does
not expose EGL_KHR_image_pixmap (which Chromium’s ozone-x11 backend
uses to wrap X11 pixmaps). The Vulkan path documented here is
therefore the only remaining option, and it’s broken by this bug.
Reproducer
Minimal MIT-licensed Rust CLI: https://github.com/nuketownada/egl-dmabuf-probe
nix run github:nuketownada/egl-dmabuf-probe -- -d /dev/dri/renderD129 --formats NV12
Or:
git clone https://github.com/nuketownada/egl-dmabuf-probe
cd egl-dmabuf-probe
nix develop --command cargo build --release
./target/release/egl-dmabuf-probe -d /dev/dri/renderD129 --formats NV12 -v
The probe allocates an NV12 GBM bo and attempts import via both
Vulkan strategies on the same dmabuf fd. Source for the two paths
in src/vulkan_import.rs (see try_import_explicit and try_import_list).
Cross-check: libplacebo (mpv) works on the same buffer
mpv --vo=gpu --gpu-api=vulkan --hwdec=vaapi <NV12 VP9 file>
→ "[vo/gpu/vaapi] using libplacebo dmabuf interop"
→ "Decoder format: 1920x1080 vaapi[nv12] bt.709 ..."
→ smooth playback, no errors
Same NV12 frames from NVIDIA’s VAAPI (NVDEC under
nvidia-vaapi-driver) imported into Vulkan via libplacebo — which is
exactly the producer/consumer pair Chromium uses, just with
libplacebo as the import layer instead of ANGLE. libplacebo’s
import call uses VkImageDrmFormatModifierListCreateInfoEXT.
(Separately: mpv --hwdec=auto picks Vulkan-native video decode
vp9-vulkan via VK_KHR_video_decode_vp9 and renders visibly
garbled output — a different NVIDIA Vulkan bug, in the video-decode
side rather than the dma-buf interop side. Mentioned for context,
not the focus of this report.)
System
- GPU: NVIDIA RTX 4000 Ada Generation Laptop GPU
- Driver: 595.71.05 (also reproduces on 555.x–580.x — see
open-gpu-kernel-modules#644 - Kernel module:
nvidia.ko.xzv595.71.05, licenseDual MIT/GPL(open variant) - Userspace: NVIDIA proprietary (
DRIVER_ID_NVIDIA_PROPRIETARY) - Vulkan API: 1.4.329
- Kernel: Linux 6.18.29 x86_64
- Tested on
/dev/dri/renderD129
(nvidia-bug-report.log.gz attached.)
Asks
In rough order of “most general fix” to “most pragmatic”:
- Make
VkImageDrmFormatModifierExplicitCreateInfoEXTaccept the
modifier+layout combination NVIDIA’s GBM produces for NV12 — the
list-based path already accepts buffers with this layout, so the
buffer is verifiably valid; the rejection appears to be in this
entrypoint’s validation specifically. - Document precisely which
(format, modifier, plane-layout)
tuples the explicit path accepts on NVIDIA so callers can know
whether to fall back to the list path. - Update NVIDIA’s Vulkan implementation notes to recommend the
list-based path over the explicit path for dma-buf imports, so
ANGLE / other clients can be patched to use what works.
The probe takes one flag to re-run against any driver
(-d /dev/dri/renderDXXX) and one line to add new format/modifier
test cases — happy to bisect a fix or verify a candidate.
nvidia-bug-report.log.gz (496.2 KB)
mpv-vk-test.log (21.1 KB)
