Description:
I am trying to configure NVIDIA GPUs on my Debian 12 (Bookworm) system using nvidia-xconfig
. However, when I attempt to use the --multigpu=Mosaic
option, I receive an error indicating that nvidia-xconfig
does not recognize the --multigpu
option. The rest of the configuration works, but I cannot enable Mosaic mode or multi-GPU settings using this method.
Steps to reproduce
- Run the following command:
nvidia-xconfig --device=Device0 --busid=PCI:0@22494:0:0 --allow-empty-initial-configuration --enable-all-gpus --multigpu=Mosaic
- Error encountered:
nvidia-xconfig: unrecognized option: "--multigpu" Invalid commandline, please run `nvidia-xconfig --help` for usage information.
System Information:
- OS: Debian GNU/Linux 12 (Bookworm)
- Kernel: 6.9.7+bpo-amd64 #1 SMP PREEMPT_DYNAMIC
- NVIDIA Driver Version: 550.120
- CUDA Version: 12.4
- GPU: NVIDIA RTX 4000 Ada Generation
root@buildhost:~# nvidia-smi
Sat Oct 5 00:52:17 2024
| NVIDIA-SMI 550.120 Driver Version: 550.120 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA RTX 4000 Ada Gene... Off | 000057DE:00:00.0 Off | Off |
| 30% 28C P8 4W / 130W | 21MiB / 20475MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 703 G /usr/lib/xorg/Xorg 6MiB |
| 0 N/A N/A 1096 G xfwm4 9MiB |
Troubleshooting Steps Tried:
- Removed
--multigpu
from the command. The configuration succeeded.
Actual Behavior:
nvidia-xconfig
option, resulting in an error.
root@buildhost:~# cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 550.120
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA RTX 4000 Ada Generation"
BusID "PCI:0@22494:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "AllowEmptyInitialConfiguration" "True"
SubSection "Display"
Depth 24
EndSubSection
EndSection
