Hi, I’m running headless on a remote g5.2xlarge ec2 instance with an A10G GPU running the NVIDIA Omniverse GPU-Optimized AMI - latest version.
It seems to work but I have warnings like this on startup:
[8.969s] Simulation App Starting
2024-09-27 09:31:17 [9,136ms] [Warning] [rtx.neuraylib.plugin] [CUDA:RENDER] 0.1 CUDA rend warn : CUDA module initialization failed.
2024-09-27 09:31:17 [9,136ms] [Warning] [rtx.neuraylib.plugin] [CUDA:RENDER] 0.1 CUDA rend warn : The version of your CUDA driver is 12.0, but 12.2 is the required minimum
2024-09-27 09:31:17 [9,136ms] [Warning] [rtx.neuraylib.plugin] [CUDA:RENDER] 0.1 CUDA rend warn : Please update your display driver (current version 525.60.11) (www.nvidia.com) to at least 535.104.05.
2024-09-27 09:31:17 [9,242ms] [Warning] [rtx.neuraylib.plugin] [IRAY:RENDER] 1.1 IRAY rend warn : Your NVIDIA driver supports CUDA version up to 12.0; iray photoreal requires CUDA version 12.2; iray photoreal can only run in CPU mode. Please update your NVIDIA driver (www.nvidia.com) to at least 535.104.05.
2024-09-27 09:31:17 [9,242ms] [Warning] [rtx.neuraylib.plugin] [IRAY:RENDER] 1.1 IRAY rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
[11.462s] app ready
2024-09-27 09:31:20 [12,086ms] [Warning] [omni.kit.imgui_renderer.plugin] _createExtendCursor: No windowing.
[12.420s] Simulation App Startup Complete
Is this normal? is the NVIDIA AMI outdated? should I install the software stack myself or maybe using the Amazon AMI?
This is the output of nvidia-smi on that machine:
