OS: windows Server 2012 x64
GPU: NVIDIA GRID K520
Driver Version: 354.1 (Link: http://www.nvidia.com/download/driverResults.aspx/95515/en-us)
I am getting ID3D10Device by hooking into DXGISwapChain::Present() method and then This->GetDevice(IID_ID3D10Device, &ppDevice);
The problem is that g_pIFR->NvIFRSetUpH264HWEncoder(&params);
returns -4 or NVIFR_ERROR_DX_DRIVER_FAILURE. Why is that?
int InitNVIFR(ID3D10Device *g_pD3DDevice)
HINSTANCE g_hNvIFRDll=NULL;
NvIFRLibrary NvIFRLib;
//! Load the NvIFR.dll library
if(NULL == (g_hNvIFRDll = NvIFRLib.load()))
return -1;
//! Create the NvIFRToH264HWEncoder object
g_pIFR = (NvIFRToH264HWEncoder *) NvIFRLib.create (g_pD3DDevice, NVIFR_TOH264HWENCODER);
if(NULL == g_pIFR)
gbx_error("Failed to create the NvIFRToH264HWEncoder\r\n");
return -1;
for (DWORD i = 0; i < NUMFRAMESINFLIGHT; i++)
//! Create the events for allowing rendering to continue after a capture is complete
g_aCanRenderEvents[i] = CreateEvent(NULL, TRUE, TRUE, NULL);
g_hThreadQuitEvent = CreateEvent(NULL, TRUE, FALSE, NULL);
//! Set up the H.264 encoder and target buffers
DWORD dwBitRate720p = 3000000;
double dBitRate = double(dwBitRate720p);
NvIFR_H264HWEncoder_Config encodeConfig = {0};
encodeConfig.dwVersion = NVIFR_H264HWENCODER_CONFIG_VER;
encodeConfig.dwAvgBitRate = (DWORD)dBitRate;
encodeConfig.dwFrameRateDen = 1;
encodeConfig.dwFrameRateNum = 30;
encodeConfig.dwPeakBitRate = (encodeConfig.dwAvgBitRate * 12/10); // +20%
encodeConfig.dwGOPLength = 0xffffffff;
encodeConfig.bEnableIntraRefresh = 1;
encodeConfig.dwMaxNumRefFrames = 16;
encodeConfig.dwProfile = 100;
encodeConfig.eRateControl = NVIFR_H264_ENC_PARAMS_RC_2_PASS_QUALITY;
encodeConfig.ePresetConfig = NVIFR_H264_PRESET_LOW_LATENCY_HQ;
encodeConfig.dwQP = 26;
encodeConfig.bEnableAQ = 1;
NVIFR_SETUP_H264_PARAMS params = {0};
params.dwVersion = NVIFR_SETUP_H264_PARAMS_VER;
params.pEncodeConfig = &encodeConfig;
params.eStreamStereoFormat = NVIFR_H264_STEREO_NONE;
params.dwNBuffers = NUMFRAMESINFLIGHT;
params.dwBSMaxSize = 256*1024;
params.ppPageLockedBitStreamBuffers = g_pMainBuffer;
params.ppEncodeCompletionEvents = g_hCaptureCompleteEvent;
params.dwTargetHeight = video_source_out_height(0);
params.dwTargetWidth = video_source_out_width(0);
NVIFRRESULT res = g_pIFR->NvIFRSetUpH264HWEncoder(¶ms);
if (res != NVIFR_SUCCESS)
if (res == NVIFR_ERROR_INVALID_PARAM || res != NVIFR_ERROR_INVALID_PTR)
gbx_error("NvIFR Buffer creation failed due to invalid params.\n");
else
gbx_error("Something is wrong with the driver, cannot initialize IFR buffers\n");
return -1;
gbx_error("NVIDIA device configured\n");
nvIfr_initialized = 1;
return nvIfr_initialized;
