Nvimageenc
GPU
• DeepStream Version
6.4
• TensorRT Version
8.6.1.6
535.171.04
Gst-nvimageenc
Its there any example or details documentation about this feature?
How do I apply it to save the bounding box of the object as a picture?
This is a plugin which can only encode the images from upstream elements in the pipeline.
You can use “gst-inspect-1.0 nvimageenc” to get more information about this plugin.
For save bbox objects as pictures, please refer to the sample /opt/nvidia/deepstream/deepstream/sources/apps/sample_app/deepstream-image-meta-test
Apply the following patch to deepstream_test_1.py,then run python3 deepsteam_test_1.py /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
This patch implements the following functions.
nvosd --> nvvideoconvert --> "video/x-raw(memory:NVMM), format=RGB" (for nvimagenc caps) --> nvimagenc --> fakesink.
Add sink probe at fakesink element, save the gst_buffer to jpeg.
diff --git a/apps/deepstream-test1/deepstream_test_1.py b/apps/deepstream-test1/deepstream_test_1.py
index 861cefc..40bc5a3 100755
--- a/apps/deepstream-test1/deepstream_test_1.py
+++ b/apps/deepstream-test1/deepstream_test_1.py
@@ -33,6 +33,7 @@ PGIE_CLASS_ID_BICYCLE = 1
 PGIE_CLASS_ID_PERSON = 2
 PGIE_CLASS_ID_ROADSIGN = 3
 MUXER_BATCH_TIMEOUT_USEC = 33000
+frame_count = 0
 def osd_sink_pad_buffer_probe(pad,info,u_data):
     frame_number=0
@@ -116,9 +117,30 @@ def osd_sink_pad_buffer_probe(pad,info,u_data):
             l_frame=l_frame.next
         except StopIteration:
             break
-    return Gst.PadProbeReturn.OK
+    return Gst.PadProbeReturn.OK
+def fake_sink_pad_buffer_probe(pad,info,u_data):
+    gst_buffer = info.get_buffer()
+    if not gst_buffer:
+        print("Unable to get GstBuffer ")
+        return
+    (result, mapinfo) = gst_buffer.map(Gst.MapFlags.READ)
+    assert result
+    try:
+        # use mapinfo.data here
+        global frame_count
+        if frame_count % 500 == 0:
+            with open(f"out_{frame_count}.jpeg", "wb") as f:
+                f.write(mapinfo.data)
+        frame_count += 1
+    finally:
+        gst_buffer.unmap(mapinfo)
 def main(args):
     # Check input arguments
@@ -174,21 +196,39 @@ def main(args):
     # Create OSD to draw on the converted RGBA buffer
     nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
     if not nvosd:
         sys.stderr.write(" Unable to create nvosd \n")
+    # Use convertor to convert from NV12 to RGB as required by nvimageenc
+    nvvidconv2 = Gst.ElementFactory.make("nvvideoconvert", "convertor2")
+    if not nvvidconv2:
+        sys.stderr.write(" Unable to create nvvidconv2 \n")
+    caps = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGB")
+    filter = Gst.ElementFactory.make("capsfilter", "filter1")
+    if not filter:
+        sys.stderr.write(" Unable to get the caps filter1 \n")
+    filter.set_property("caps", caps)
+    nvimageenc = Gst.ElementFactory.make("nvimageenc", "nvimageenc")
+    if not nvimageenc:
+        sys.stderr.write(" Unable to create nvimageenc \n")
     # Finally render the osd output
-    if is_aarch64():
-        print("Creating nv3dsink \n")
-        sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
-        if not sink:
-            sys.stderr.write(" Unable to create nv3dsink \n")
-    else:
-        print("Creating EGLSink \n")
-        sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
-        if not sink:
-            sys.stderr.write(" Unable to create egl sink \n")
+    # if is_aarch64():
+    #     print("Creating nv3dsink \n")
+    #     sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
+    #     if not sink:
+    #         sys.stderr.write(" Unable to create nv3dsink \n")
+    # else:
+    #     print("Creating EGLSink \n")
+    #     sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
+    #     if not sink:
+    #         sys.stderr.write(" Unable to create egl sink \n")
+    sink = Gst.ElementFactory.make("fakesink", "fakesink")
+    if not sink:
+        sys.stderr.write(" Unable to create fakesink \n")
     print("Playing file %s " %args[1])
     source.set_property('location', args[1])
@@ -208,6 +248,9 @@ def main(args):
     pipeline.add(pgie)
     pipeline.add(nvvidconv)
     pipeline.add(nvosd)
+    pipeline.add(nvvidconv2)
+    pipeline.add(filter)
+    pipeline.add(nvimageenc)
     pipeline.add(sink)
     # we link the elements together
@@ -227,7 +270,10 @@ def main(args):
     streammux.link(pgie)
     pgie.link(nvvidconv)
     nvvidconv.link(nvosd)
-    nvosd.link(sink)
+    nvosd.link(nvvidconv2)
+    nvvidconv2.link(filter)
+    filter.link(nvimageenc)
+    nvimageenc.link(sink)
     # create an event loop and feed gstreamer bus mesages to it
     loop = GLib.MainLoop()
@@ -244,6 +290,12 @@ def main(args):
     osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
+    fakesinkpad = sink.get_static_pad("sink")
+    if not fakesinkpad:
+        sys.stderr.write(" Unable to get sink pad of fakesink \n")
+    fakesinkpad.add_probe(Gst.PadProbeType.BUFFER, fake_sink_pad_buffer_probe, 0)
     # start play back and listen to events
     print("Starting pipeline \n")
     pipeline.set_state(Gst.State.PLAYING)
