I am trying to use TensorRT for running inference on a tensorflow model that I converted to UFF.
I am trying to use my GPU unified memory to hold the the activation data. However, my code is failing to create an execution context i.e when context = engine->createExecutionContextWithoutDeviceMemory();
is executed, a null pointer is returned and I get the following error:
[02/12/2020-09:29:57] [I] [TRT] Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
[02/12/2020-09:30:03] [I] [TRT] Detected 1 inputs and 1 output network tensors.
Creating execution context
140557824 602112
[02/12/2020-09:30:03] [E] [TRT] …/rtSafe/cuda/caskConvolutionRunner.cpp (233) - Cuda Error in allocateContextResources: 1 (invalid argument)
[02/12/2020-09:30:03] [E] [TRT] FAILED_ALLOCATION: std::exception
However if I run context = engine->createExecutionContext()
instead the execution context is getting created successfully. Can someone please help me with this?
Here is my code.
int main(){
std::cout << "\n Running \n";
IBuilder* builder = createInferBuilder(gLogger);
INetworkDefinition* network = builder->createNetwork();
nvuffparser::IUffParser* parser = nvuffparser::createUffParser();
parser->registerInput(INPUT_BLOB_NAME, DimsCHW(3, 224, 224), nvuffparser::UffInputOrder::kNCHW);
parser->registerOutput(OUTPUT_BLOB_NAME);
//const auto explicitBatch = 1U << static_cast<uint32_t>(NetworkDefinitionCreationFlag::kEXPLICIT_BATCH);
parser->parse("/mnt/model/inception/inception.uff", *network, nvinfer1::DataType::kFLOAT);
builder->setMaxBatchSize(maxBatchSize);
IBuilderConfig* config = builder->createBuilderConfig();
config->setMaxWorkspaceSize(1 << 20);
ICudaEngine* engine = builder->buildEngineWithConfig(*network, *config);
parser->destroy();
network->destroy();
config->destroy();
builder->destroy();
std::cout<<"Creating execution context"<<endl;
size_t engine_size = engine->getDeviceMemorySize();
std::cout<<engine_size<<" "<<sizeof(float)*224*224*3<<endl;
IExecutionContext *context;
//context = engine->createExecutionContext();
if (context == nullptr){
std::cout<<"FAILED ALLOCATION"<<context<<endl;
exit(-1);
