**• Hardware Platform NVIDIA Corporation GA102GL [RTX A6000] (rev a1)
**• DeepStream Version 6.2
**• TensorRT Version 8.6.1
**• NVIDIA GPU Driver Version (valid for GPU only) 525.116.04 • Issue Type( questions, new requirements, bugs)
The current issue I am having is when I try to run the following Gstreamer pipeline:
I get the following error:
max_fps_dur 8.33333e+06 min_fps_dur 2e+08
Setting pipeline to PAUSED …
WARNING: [TRT]: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage and speed up TensorRT initialization. See “Lazy Loading” section of CUDA documentation CUDA C++ Programming Guide
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [FullDims Engine Info]: layers num: 2
0 INPUT kFLOAT input.1 1x635x128 min: 1x1x635x128 opt: 2x1x635x128 Max: 2x1x635x128
1 OUTPUT kFLOAT output1 31 min: 0 opt: 0 Max: 0
0:00:04.783780313 72216 0x564f35b5b6d0 WARN nvinferaudio gstnvinferaudio.cpp:282:gst_nvinferaudio_start: error: Failed to create audio transform
ERROR: from element /GstPipeline:pipeline0/GstNvInferAudio:nvinferaudio0: Failed to create audio transform
Additional debug info:
gstnvinferaudio.cpp(282): gst_nvinferaudio_start (): /GstPipeline:pipeline0/GstNvInferAudio:nvinferaudio0
ERROR: pipeline doesn’t want to preroll.
Pipeline is PREROLLING …
0:00:04.784482636 72216 0x564f35b5c300 WARN basesrc gstbasesrc.c:3132:gst_base_src_loop: error: Internal data stream error.
0:00:04.784498936 72216 0x564f35b5c300 WARN basesrc gstbasesrc.c:3132:gst_base_src_loop: error: streaming stopped, reason not-negotiated (-4)
ERROR: from element /GstPipeline:pipeline0/GstFileSrc:filesrc0: Internal data stream error.
…/libs/gst/base/gstbasesrc.c(3132): gst_base_src_loop (): /GstPipeline:pipeline0/GstFileSrc:filesrc0:
Setting pipeline to NULL …
I am confused as I am using only sources that are provided by the SDK. It doesn’t seem to be a pipeline error either and its the nvinferaudio element that is not working properly.
please refer to deepstream audio sample opt\nvidia\deepstream\deepstream-6.2\sources\apps\sample_apps\deepstream-audio\deepstream_audio_main.c
if still can’t work, could you share the nvinferaudio’s configuration file?
0:00:04.760803577 215096 0x55728d6b8530 WARN nvinferaudio gstnvinferaudio.cpp:282:gst_nvinferaudio_start: error: Failed to create audio transform
0:00:04.761707381 215096 0x55728d118360 WARN basesrc gstbasesrc.c:3132:gst_base_src_loop: error: Internal data stream error.
0:00:04.761724263 215096 0x55728d118360 WARN basesrc gstbasesrc.c:3132:gst_base_src_loop: error: streaming stopped, reason not-negotiated (-4)
0:00:04.761742427 215096 0x55728d118400 WARN basesrc gstbasesrc.c:3132:gst_base_src_loop: error: Internal data stream error.
0:00:04.761761162 215096 0x55728d118400 WARN basesrc gstbasesrc.c:3132:gst_base_src_loop: error: streaming stopped, reason not-negotiated (-4)
ERROR: from element /GstPipeline:pipeline0/GstFileSrc:filesrc1: Internal data stream error.
…/libs/gst/base/gstbasesrc.c(3132): gst_base_src_loop (): /GstPipeline:pipeline0/GstFileSrc:filesrc1:
it is because audio-transform is not set in configuration file. please refer to readme in deepstream-audio and sample in \opt\nvidia\deepstream\deepstream-6.2\sources\apps\sample_apps\deepstream-audio\configs\ds_audio_sonyc_test_config.txt
but now I am coming into another issue that being:
unsupported param type
** (gst-launch-1.0:250147): ERROR **: 09:32:15.694: Failed to transform parameter
Trace/breakpoint trap (core dumped)
Is this because the parameters for the audio-transform are not exactly configured to what the audio given into is? or is this something entirely different?
Furthermore, When I run gst-inspect-1.0 nvinferaudio
in the Element Properties section this is what is provided for this:
audio-transform : Transform name and parameters
flags: readable, writable
Boxed pointer of type “GstStructure”
How would I express a Boxed pointer of type “GstStructure” in the CLI?
After some more testing I found that if you put the audio transform gst property all in quotations that works. Like this: “audio-tr
ansform=melsdb,fft_length=2560,hop_size=692,dsp_window=hann,num_mels=128,sample_rate=44100,p2db_ref=(float)1.0,p2db_min_power=(float)0.0,p2db_top_db=(float)80.0”
however when I run this pipeline it seems to only deal with the first 3 seconds of the entire 10 minute video.
let’s focus on this topic Nvstreammux receives a random EOS
Seems the nvstreammux changes the timestamp. We are investigating the issue. Will be back when there is any progress.
