I looked at the documentation for nvinferserver
but it is not clear how to set a Triton Server mode as a secondary model. I haven’t found an example either.
I tried to do that, and it seems to work fine, but I get the following error:
Warning: gst-library-error-quark: NvInferServer asynchronous mode is applicable for secondaryclassifiers only. Turning off asynchronous mode (5): gstnvinferserver_impl.cpp(352): validatePluginConfig (): /GstPipeline:pipeline0/GstNvInferServer:mymodel-nvinference-engine
Why is that? How can I get to run it asynchronously? This is my model configuration.
infer_config {
unique_id: 10
gpu_ids: [0]
max_batch_size: 64
backend {
trt_is {
model_name: "mymodel"
version: -1
model_repo {
root: "/src/pipeline/models/repository"
log_level: 2
preprocess {
network_format: IMAGE_FORMAT_RGB
tensor_order: TENSOR_ORDER_LINEAR
maintain_aspect_ratio: 0
normalize {
scale_factor: 1
channel_offsets: [0, 0, 0]
postprocess {
other {}
extra {
copy_input_to_host_buffers: false
custom_lib {
path: "/opt/nvidia/deepstream/deepstream/lib/libnvds_infercustomparser.so"
input_control {
operate_on_gie_id: 1
operate_on_class_ids: [0]
async_mode: 1
object_control {
bbox_filter {
min_width: 64
min_height: 64
process_mode: PROCESS_MODE_CLIP_OBJECTS
interval: 0
output_control {
output_tensor_meta: true
Following the documentation here Gst-nvinferserver — DeepStream 6.0 Release documentation I also tried to set process_mode: PROCESS_MODE_FULL_FRAME
at the root level of the configuration file, but then I get the error:
[libprotobuf ERROR /home/amkale/jitendrak/Triton-Github/client/build/_deps/repo-third-party-build/grpc-repo/src/grpc/third_party/protobuf/src/google/protobuf/text_format.cc:317] Error parsing text-format nvdsinferserver.config.PluginControl: 50:13: Message type "nvdsinferserver.config.PluginControl" has no field named "process_mode".
