Nvinferserver : Do post porcessing on image buffer and send it back to DeepStream pipeline
• Hardware Platform (Jetson / GPU) Jetson Orin
• DeepStream Version 6.1
• JetPack Version (valid for Jetson only) 5.0
• TensorRT Version 8
• Issue Type( questions, new requirements, bugs) Questions
Hi ! I am using nvdsinferserver with triton to run a segmentation model with Deepstream. I want to do post processing within Triton using the python backend to draw polygons and other shapes that Nvosd cannot handle on the image buffer and push it back to the pipeline. Is this possible? Because if i refer to the nvdsinferserver documentation page, the figure only indicates that only metadata is being pushed back to Deepstream pipeline and not the entire buffer. If yes could you provide code snippet ? Thank you in advance!
do you mean want to draw on frame before nvosd ?
  1. Nvosd can draw polygons ,please refer to Gst-nvdsosd — DeepStream 6.1.1 Release documentation
  2. you can add display meta in probe function, nvosd will process these meta, please refer to osd_sink_pad_buffer_probe in deepstream-test1.
  3. some code in probe function, Push frame back to DeepStream pipeline inside a probe function
