aaron39
November 19, 2024, 6:54pm
1
When I run this python script, it exits with a “Segmentation fault (core dumped)”. When I remove the GdkX11
import, it works.
import gi
gi.require_version("Gst", "1.0")
gi.require_version("GdkX11", "3.0")
from gi.repository import Gst, GdkX11
Gst.init(None)
nvjpegdec = Gst.ElementFactory.make("nvjpegdec", "nvjpegdec")
Deepstream 7.0
dGPU NVIDIA GeForce RTX 3060
NVIDIA-SMI 560.35.03 Driver Version: 560.35.03 CUDA Version: 12.6
TensorRT v8601
yuweiw
November 20, 2024, 6:21am
3
We’ll investigate this issue. Can you tell us why you need to use GdkX11
aaron39
November 21, 2024, 2:07am
4
I’m not dependent on GdkX11, it was just a way to distill the crash. It segfaults with just Gdk also. I use that get draw on Pixbufs.
import gi
gi.require_version("Gdk", "3.0")
Gst.init(None)
yuweiw
November 21, 2024, 2:37am
5
OK. There might be some compatibility issues between the libjpeg.so
and the libnvdsgst_jpeg.so
Could you try to set the LD_PRELOAD
macro first?
export LD_PRELOAD=$LD_PRELOAD:/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpeg.so
aaron39
November 21, 2024, 6:54am
6
Setting LD_PRELOAD as suggested solves my trivial example, but when I try it on my real application it just hangs. It doesn’t segfault, but it doesn’t run either.
I do notice that if I just postpone importing Gdk or Gtk until after the nvjpegdec
is loaded, it seems to work.
import gi
gi.require_version("Gtk", "3.0")
Gst.init(None)
from gi.repository import Gtk
yuweiw
November 21, 2024, 7:39am
7
Glad to hear that. Perhaps this order of API calls avoids the lib compatibility issues.
