ykwon
#1
Hey,
I’m trying to create an object in shared memory but I’m getting the following error
nvlink error : Undefined reference to ‘tt’ in ‘./MyClass.o’
make: *** [MyProject] Error 255
I’m creating the object in my Kernel in the following way
global void myKernelFunction(inputs)
extern shared MyObject tt;
tt = MyObject(input);
//rest of code
I’m also allocating shared memory in the kernel call with
//some code
myKernelFunction<<<numBlocks, numThreads, sizeof(MyObject)>>>(inputs);
//more code
Note that even this won’t work:
extern shared int sdata;
Per the documentation, use the array (i.e. ) syntax:
http://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#shared
tt[0] = MyObject(inputs);
For example, this compiles successfully for me:
class MyObject {
public:
int idata;
float fdata;
__host__ __device__
MyObject(){
idata = 0;
fdata = 0.0f;
__host__ __device__
MyObject(int _idata){
idata = _idata;
fdata = 0.0f;
__global__ void kernel() {
extern __shared__ MyObject tt[];
tt[0] =MyObject(0);
int main()
kernel<<<1,1, sizeof(MyObject)>>>();
return 0;
